20 Most Recent
Remington Precision HC-8017 Hair Trimmer Questions & Answers
My clippers are no longer cutting. I took it apart
there is probably hair stuck between the cutters
remove the cutters from the clipper and you can push the top blade out from under the spring retainer making sure you keep the small plastic runner strip
clean the surfaces and using a flat bladed screw drive insert the blade under the spring and twist slightly to allow the top blade to slide back in
while it feels sharp , it is the sides of the cutter fingers that cut the hair ( like miniature guillotines) and those edges are easily worn off
5/4/2017 10:57:18 AM •
Remington...
Answered
on May 04, 2017
How and where do I lube the blades
i don't have the exact same product as you but i do have an electric hair trimmer. instructions for mine: use mineral oil : spread a thin coat over the blades, turn it "on" for a few seconds, then reapply a second thin coat. wipe off any excess, what oil that is left behind is a very thin coating: perfect! do this every fourth time you use it.
7/5/2013 6:20:09 PM •
Remington...
Answered
on Jul 05, 2013
