20 Most Recent Panasonic NN-T888S Convection/Microwave Oven Questions & Answers
Other than a complete power off, I know of no reset switch on any microwave ovens. I own a panasonic myself.
I would leave it unplugged for a while, at least 15 minutes or so, and leave the door open, to turn on the inside light (which won't light if unplugged but) so it might discharge any capacitors holding residual power to the circuit.
If it wasn't power protected, it could have taken a hit.
If it is plugged into a surge protector, they wear out. You might be able to make a claim on it through the surge protector manufacturer, if it has a warranty, and you have receipt. Surge protectors do wear out, and most unless they're the cheapest, will have a warranty that covers equipment. The wear out because the varistor which provides the voltage clamping during a surge become conditioned. Initially they clamp around 150V to 180V, but as they age from repeated surges, their clamping voltage rises until it no longer protects the equipment. Often you can tell, if the surge protector LED is blinking or intermittent, the company will replace the surge device if you make a claim on the protector, if it fails while in use, they usually cover the equipment, unless the warranty has run out, but many give lifetime warranties.
The reason some keys may have been working is because after a small surge, the logic states can go indeterminate, which means some work, and some won't. If it's not damaged, a full power off for some time may restore it to initial conditions.
Hope this helps. They should build in surge protection, and I think mind does have some; but, if not, I hope it's in warranty for you.
Panasonic... | Answered on Jul 04, 2017
There is a transformer which powers the front panel. Normally attached to the front panel bord. If the transformer is faulty the such problems can occur.
If you wish to get some more details about microwave oven repair then check the below added link http://electro-medical.blogspot.com/
Panasonic... | Answered on Jul 06, 2016
Ken,
Usually there is an internal fuse and that is probably your problem. You will need to take off the outside cover of your microwave and then look where the power cord goes into the back of the unit. Look for the black wire coming out of the power cord and follow it. It should take you to the fuse. Hope this helps!
Panasonic... | Answered on Dec 16, 2014
I have the same microwave. As far as I can tell the inverter went out to the first one. I now have two and use the first one as spare parts. But that said I tried to use the new inverter in the old oven and is didn't work. so I had to be leave the problem could be the control board.
Panasonic... | Answered on May 15, 2014
At this time we recommend you use the below link to locate an authorized service center.
www.panasonic.com/repair Welcome to Panasonic Online Repair
Panasonic... | Answered on Mar 28, 2014
There's a grating for the interior light, and another panel a little further back for the microwave output of the magnetron. The microwave panel should not have a hole in it. That would probably indicate some kind of magnetron failure. Not user serviceable. Time to visit a competent tech and/or a service facility.
Panasonic... | Answered on Mar 06, 2014
Hi Michael,
i think something wrong with its high-tension circuit or your magnitron is bad.
the minor fault is open of therm stat for protection.
or burnt fuse in circuit.
regards,
nuwan.
Panasonic... | Answered on Jan 09, 2014
I have this NN-C780P Microwave/Convection Oven. The microwave mode is not working and baking was ok until recently, the turntable cannot rotate when the temperature, timing and baking are ok.
When I bake, there are knocking sound.
Please advise.
Panasonic... | Answered on Nov 21, 2013
microwave should work with out the plate as the plate turning the food is for cooking evenly for warming porpuses there should be no problem
Panasonic... | Answered on Oct 19, 2013
A membrane switch is a type of electrical switch. It's often used in kitchen appliances because they have no external moving parts and thus are immune to splashes and dirt. See http://en.wikipedia.org/wiki/Membrane_switch
Panasonic... | Answered on Aug 21, 2013
PLEASE CHANGE MEMBRANE SWITCH
Panasonic NN-T888S Convection/Microwave Oven Logo
136 questions posted
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Paul Bade
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Microwave Ovens
Most Popular Question
panasonic dimension 4 microwave
  • Microwave Ovens
