20 Most Recent
Pride Mobility Products Jazzy 1103 Ultra Electric Wheelchair with Powered Seat Lift by Pride Mobili Questions & Answers
How too reprogram joystick for speed, changed
Many power wheelchair controllers are able to be programmed for speed, acceleration etc. There is normally a separate programmer that you need to plug ino the the power wheelchair. Your supplier should have one of these.
If you do not know your local supplier, have a look on the manufacturers website. If it is pride mobility, then try
www.pridemobility.com.
Jazzy jet 3
Look in your owners manual for the flash code anwser. Make sure when you hit the power button you only touch it for 1 sec not more. If you press the power button for more the 2-3 seconds you place the power chair in LOCK OUT mode. lights will flash and not power. also check your free wheel levers. one on each moter. Mike
Pride elite traveller 4 a knock when driven coming
hi,
Sounds to me like the worm drive is slipping , this can happen when the worm drive small bearing is worn,
If you do take it a part , please take great care, the shaft from the motor will have a worm drive, two bearings on the worm drive,
Try to move the shaft within the bearings, I paid £10 for replacement bearings.
Please give me a update.
Regards
GeWiz.
