20 Most Recent
Amigo HD450 3-Wheel Scooter w/33AH Batteries - Color Cinnamon Red - Value M Questions & Answers
Control module smoked !
what about calling the people who made the scooter and ask them for help. also if you can not afford a new one sometimes community groups like Rotary or the Lions club will sponsor life aids, especially for younger people they are all about good quality of life! give it a try, nothing to loose and you might just get a new scooter! hope it helps.
I have a Fiesta by Amigo, When I turn the switch
check here there are different codeshttp://myamigo.com/amigo-mobility-scooters-support/amigo-mobility-scooters-owners-manuals.html?download=20%3Aamigo-rtexpressjunior-amigo-rd-amigo-ext350-amigo-hd450-amigo-mc-amigo-mcx-2003-present
Where is the serial number
normally at the bottom of the steering column it there's o boot look under itor in the battery compartment next to the batteries
I bought an older Amigo
look on the inside of the wheel there should be bolt and nut going thru the wheel and axle you'll need a long Allen wrench and nut driver to remove and the wheel pulls offsorry not sure what size wrenches
Battery fully charged wii not run
Hi. We need a bit more info. Any lights flashing, if so how many flashes between the pauses.
Have you checked the free-wheel lever is in the correct position?
Did the machine suddenly become faulty, or has it had faults for a while?
Good luck. Neil.
I have an amigo RT,
check the charger, if you plug it in the indicator should blink for aprox. 30 sec. then go solid and when charge is complete the indicator will start to blink again, also if the charger is working the scooter should not move when plugged in, if charger not working check power cord before replacing charger
