20 Most Recent
RTO AquaScape 4500 GPH Pump Questions & Answers
Pump runs for about 3 to 5 minutes and then cuts
You have checked that sure thing, but if you have that pump on a shared circuit that thing draws more amps than normal appliances or is competing with another appliance and popping the circuit. Try isolating the pump and also make sure the circuit can handle the amp load the pump is giving off. Hope this is helpful.. Good Luck!
I have a AquaScape 4500 GPH Pump it has worked
Where the wire goes into the pump there is a o ring thatis probably leaking and any sort of water the motor might be getting is tripping the breaker. You probably have it plugged into a gfi and it sense very low amounts of water, and trips, You can determine by plugging it into a regular outlet and it should work. But definently fix the oring at the point of entry on the pump
Shuts off intermittantly
Does it come back on after resting/cooling down. If does peobably kick out on heat overload and is resetting itself. If impeller is free spinning with NO roughness or side play in bearing probably too much head pressure,pumping too far or too small pipe wich will cause excessive pressure making pump work to hard
Aquascape 4500 not working
Typical with these pumps, pumps I have rebuilt that have done the same thing what happens is the bearings get loos and cocks the armature that is why it won't spin. I did serious research on these pumps and came up with a rebuild kit some parts bought some I make. I did mine 2 years ago and still working like a champ and have done over 20 locally with no problems. If your pump is noisy or the impeller has fallen off (typical) due to water getting in the unit and causing the bearings to fail
email me and I can rebuild your pump. The process is simple send me the pump I will look at it and see if it can be rebuilt at NO CHARGE if it can be rebuilt you will
save over 60% of a new one. Don't spend $349 - $599 on a new one let me look at it for free if I can rebuild it great if not you will have to buy a new one. I am not a dealer for any pumps so you will not have to worry about me selling you a pump and if you want the old one back pay the shipping and it it all yours.
Stops running after warms up
It's eithe your coil ha heat soak and needs replacing or your fuel circuit isn't venting properly and is creating a negative pressure
11/22/2013 10:43:17 AM •
RTO Garden
Answered
on Nov 22, 2013
