20 Most Recent
Garmin Nuvi 200w 250w 260w 580 660 670 680 Carrying Case Questions & Answers
My new nuvi 255w will not start displaying info
When using a usb from your computer it is only a trickle
charge to the garmin. Will take a day or two to fully charge. If you use a the cigarette lighter plug that came WITH the garmin, it will fully charge in 4 hours. Stick with garmin approved plugs and all will go smooth. I know, I made the same error.
Why wont my computer recong my garmin
To let a computer work with a Garmen, you need to install software that came with your GPS. On the disk are also all drivers for all known operating systems.
First install the software, than connect.
Format my gps usb restart show logo and restart
Well to avoid this problem you can do a hard reset, that reset set all the settings to factory default and it again format in fat file system, Turn the unit off. Hold your thumb on the bottom right of screen and turn it on, keeping your thumb there. Say "Yes" when prompted. Please post comments if further you have the same problem......
Good Luck!!
Thanks
How to register my nuvi 200w
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
To Register your Garmin GPS go to: https://my.garmin.com/mygarmin/customers/myGarminHome
Have your model and serial number handy
I get the message
Normal
0
false
false
false
font-size:10.0pt;
The "No Detailed Maps Found That Support
Routing" message may appear on your device for the following reasons:
- The GPS device is
missing it's unlock code
- The maps on the GPS
device have been disabled
To determine the cause of the message, touch the
screen until the message "No Detailed Maps Found That Support
Routing" disappears.
- If you see a "Can't
Unlock Maps" message following this error, remove any microSD / SD
cards in the device and follow the instructions below for Retrieving your
unlock codes followed by the instructions for Creating an unlock file
- If you do not get the
Can't Unlock Maps message then skip to the instructions for Enabling maps
on the GPS device
Retrieving your unlock codes:
- Log into your myGarmin account
- Select myMaps
- Select Manage Maps
- Select the device from
the drop down menu
- The unlock code is
located under the "Maps installed on this device" section
Need manual so I can print it.
Go to Garmin's website- you should be able to download it from there. One word of advice though; unless you want to burn through about 100 pages of paper or so, I would just save the manual to your computer so you have a "soft" copy.
Now have letters missing and some are duplicated.
Normal
0
false
false
false
font-size:10.0pt;
If a nuvi 200 is has an older version of
system software a certain glitch may occur. The device may be missing letters
or have jumbled letters or displaying duplicate letters or strange symbols on
the address screen. To correct this you will need to update the system software
of your nuvi. You can easily do this by using Garmin's WebUpdater program:
- Click the following link
to download the WebUpdater program: http://www.garmin.com/products/webupdater/howtoinstall.jsp
- Follow the on screen
prompts from the website
- Choose RUN/OPEN
prompts
After the program has been installed it should run
automatically. If it does not please use the steps below.
To run WebUpdater:
- From the Start menu,
click All Programs and find the Garmin folder
- Click WebUpdater
- Connect your nuvi
to an available USB port on your
computer
- To search for an
available update, choose NEXT
- As the program
automatically finds updates, choose NEXT to load the update. Once the
update is complete, you can search for other updates such as voice
languages, Bluetooth, and Traffic Receiver.
- Disconnect the unit to
ensure it powers on.
Take your unit outdoors and keep it in a
stationary position with an open sky view until it reacquires satellites.
My Garmin nuvi 260 is only 6 months old and it can
First make sure you have the latest software in it.
If it does try a Master Reset.
Lastly, unless you're in a strange location with poor reception. Take it back. Or, it's still under warranty.
Normal
0
false
false
false
font-size:10.0pt;
To perform a
Master Reset on your
nuvi 260 series device:
Note: A master reset will erase all waypoints or favorites
and will restore your unit to the default factory settings.
- Start with the unit OFF
and unplugged from power
- Touch and hold the lower
right corner of the screen with an index finger or the eraser end of a
pencil
- Continue touching and holding
the lower right hand corner of the screen then power the unit ON
- Release the power button when
the device powers ON
- You will see a new message:
Do you really want to erase all user data?
- Remove your finger from the
touchscreen when this message displays
- Touch Yes
The device will automatically reset. Follow the on screen prompts then place
your device in an area with a clear view of the sky until it acquires
satellites.
