20 Most Recent
RIM Blackberry 8320 Curve Car Charger Questions & Answers
The trackball is not functioning down ward... but
Everyone has the problem like yours. The blackberry trackball will get sticky unscrollable. No need to replace or disassemble. Find out the rotating straw trick at http://www.unique-stuff.co.cc/fixing_sticky_blackberry_trackball.html
Sim Card
Call the customer servide dept, for the card that you are using, be it Rogers, Fido, AT & T, or whatever and ask them to check the numbers on the card. I'm assuming you are doing this to see if the card is still active or not.
My black berry goes off on its on,
try taking the prongs that the battery touches and lightly bending them out a bit for a better connection. also make sure the prongs are not corroded. If they are, you can clean with cotton swab and rubbing alcohol.
How to open unlock blackberry 8310
Hello. You can unlock a Blackberry 8310 safer and easier using unique unlock code. You can get the unique unlock code for a Blackberry 8310 from
ProUnlocking.com at affordable cost with an easy unlocking guide. Good luck.
