20 Most Recent
Panasonic ER 240 Beard Trimmer Questions & Answers
Machine does not work inspite
If the cells had leaked it could have seeped into the inner circuit . So it will be better to have this cleaned and checked for line break,.checck the motor within if failed or jammed.
The battery is not keeping the charge
Time to change the battery , you must open the unit carefully to get access after confirming that with the charging done for 48 hours the battery does not stay.
What is the use of
To reduce friction in the cutters. If you don't keep the cutters lubricated they will blunt and stick easily.
Power cable for er240?
I could not find just the power cable anywhere online, but I found the save shaver on ebay for 25 dollars. You could just use two AA rechargable batteries and get a charger for the batteries. :)
