20 Most Recent
Buck Dodge Ram 1500 2002 Car Radio/stereo Wire Harness Plug Questions & Answers
02 dodge ram 1500 4+4.Shaking in front end only
probably are warped
machining warped rotors only fixes the problem until they get hot again and they again warp as they are now thinner than before
the problem could be in worn suspension rubbers and ball joints
so have the front end checked out
if it turns out to be rotors , buy quality after market units and quality disc pads
have the abs system also checked out as the system indicates a braking action similar to when the abs is activated
We have a 2002 Dodge Ram 1500 that is jerking into
Drain the transmission fluid & remove the filter.
Install a new filter & transmission gasket.
Noticed the amount of fluid coming out, then put in new fluid at that amount.
Open the engine hood.
Remove & get access to the MAP/air flash system, clean it out very well without breaking or bending anything.
Code p0340
A mechanic always checks for compression, spark and fuel pressure first. Then timing and fuel quality. With timed spark, compression and fuel, there should be combustion. Running then becomes a function of the other control systems.
Need to find out what
Fig. Cylinder head torque sequence-4.7L engine
Install the cylinder heads. Use new gaskets and tighten the bolts, in sequence, as follows:
Step 1: Bolts 1-10 to 15 ft. lbs. (20 Nm)
Step 2: Bolts 1-10 to 35 ft. lbs. (47 Nm)
Step 3: Bolts 11-14 to 18 ft. lbs. (25 Nm)
Step 4: Bolts 1-10 plus
(90 degree) turn
Step 5: Bolts 11-14 to 19 ft. lbs. (26 Nm)
Hope this helps (remember to rate and comment this answer).
Dodge 1500 service engine soon
Need to get A/C levels checked and might need more freon and go to the auto parts store and have them run an OBD2 scan on your truck. Than go to www.canobd2.com and put your vehicle and code in and see what that code is in reference to.
Rear speaker does not work
if the car has the factory amp you neeed to turn it on or bypass it to hear the soundin the back call me for more questions at 520-882-8979
@002 Dodge Ram. Check engine light on. Code 1491
the condensor fan for the a/c is electric and probably has a blown fuse th ecode for a bad ecm (engine control computer ) is p0605 if you don't have that code the computer is likely ok computer failures are rare
