20 Most Recent
Vector 1 Million Power Series Spotlight & Air Inflator Questions & Answers
I need a recharge cord
This model has a built in charger so all you need is an extension cord. You will find the plug in underneath the black rubber flap that is located on the side.
Need a recharger cord for my Vector VEC270S,
In March, 2006, Black & Decker purchased Vector Products, Inc.
Since the acquisition, Black & Decker has assumed the manufacturing
of all Vector products. For customer service and warranty information
for Vector products, please contact
Black & Decker Customer Service.
The Vector VEC270S has a built in charger and can be recharged by connecting it to a extension cord.
After unit has been charged
I have several of these units and their lights have never blinked either. Just charge it until the green light comes on and that should be sufficient.
"rechargeable" battery will not take a charge at
Actually it is a very simple thing to do:
First you need to take the unit apart --it is tedious, but easy to do (just keep track of all the different types of screws and where they go as you go along... There are approximately 20 of them...)
Once you open it, you will immediately see the batteries --most likely it is two batteries-- that you will need to replace. The best way to get them, at the best price, is online at
www.batterymart.com (I just bought two from them to replace the batteries on my VEC280... and it is working just fine once again.)
I have a friend how
check the lite bulb. Might be burned out and if so, it needs to be replaced.
I need a replacement bulb for a Vector VEC139BW 3
I just bought 3 from "The Bulb Man" 2207 Elmwood Ave. Buffalo, N.Y. 14216 (716) 875-2852. He had to order, they came in in about a week. They work fine but bulb has no blue tint, I'm starting to look for the area light when I found this. Bulb, base & wire is all one piece. I think I paid $12-14 for all three a few weeks ago. (Aug 2010)
The air compressor attachment broke. Is there a
I purchased a replacement part (air chuck) at Wal*Mart. Lubricate the end with soap so it will slide inside the hose and then secure it with a small hose clamp. And, as previously stated. In March, 2006, Black & Decker purchased Vector Products, Inc. Since the acquisition, Black & Decker has assumed the manufacturing of all Vector products. For customer service and warranty information for Vector products, please contact Black & Decker Customer Service.
www.blackanddecker.com/CustomerCenter/Default.aspx
I DO NOT HAVE THE POWER CHARGING CORDS... ONLY
On the side of the unit is a small black flap that covers two prongs that you can plug a standard 110-120 volt extension cord into which will charge the unit. There are 3 read lights and 1 green lights on the top that lets you know when it is fully charged. The 12 volt charging cord is basically a cord that has 2 cigarette lighter plugs. One plugs into the unit and the other plugs into a power port/cigarette lighter plug.
Is the function of one-half a large, small, or in
Ingredients:
- 8- 1 ounce
squares of unsweetened chocolate
- 1 cup butter
- 5 eggs
- 3 cups sugar
- 1 tablespoon vanilla
- 1-1/2
cups flour
- 1 teaspoon salt
- 2-1/2 cups chopped pecans or walnuts, toasted
Preparation:
Preheat oven to 375
degrees F. Grease a 9 x 13 pan.
Melt chocolate and butter in a saucepan over low heat; set aside. In a
mixer, beat eggs, sugar and vanilla at high speed for 10 minutes**.
Blend in chocolate mixture, flour and salt until just mixed. Stir in the
nuts. Pour into prepared pan.
Bake for 35-40 minutes. (Don't overbake.) Cool and frost if desired, but
that is not necessary.
** It's not required, but this is when it's very nice to own a stand
mixer.
This is one of the best brownie recipes.
I have a mod # vec280pob the white plastic gear
Vector was bought by Black and Decker in 2006, you can get Info, order parts or find a Service Center at this link;
http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Light wont light up
The rechargable battery is dead, it has just enough juice to light the LED but nothing else. You can order a replacement battery from
www.dewaltservicenet.com All Vector Products, Service and Parts are sold by Black and Decker which purchased Vector in 2006. The products are rebranded under the Black and decker name now.
How do i charge it
Should have come with a charger or 12volt adaptor to plug in to cig lighter
