20 Most Recent Panasonic KX-TG2356 Cordless Phone Questions & Answers
Panasonic Phone Keeps De-Registering
This solution is for the KX-TG2356 cordless phone The problem you are having is not that the handset is de-registering but your handset is losing the link to the main base.You said you went through 6 handsets then, the only remaining thing that could cause your problem is: A bad handset battery. This would give you all types of connection problems and the Main base. I will begin with replacing the battery. If that does not solve your problem then the problem would be the main base
4/19/2017 12:50:54 PM • Panasonic... • Answered on Apr 19, 2017
How can I retrieve a deleted outgoing greeting? My husband passed away and it was his voice on the greeting. Please tell me how I can get it back?!!?
Knowing the importance of this specific case I would highly recommend calling the factory and having the read the chip (s) and retrieve the data aside from that there's no other way for a consumer to retrieve lost greetings unless you might have had it pre-recorded somewheres just in case he wasnt there and you needed to reset up your answering machine. Hopefully this helps. Sorry for your loss by the way .
5/3/2016 4:37:06 AM • Panasonic... • Answered on May 03, 2016
Showing ] P
after instead of name restart phone...
4/1/2014 8:27:30 AM • Panasonic... • Answered on Apr 01, 2014
0answers
0answers
0answers
0answers
Fujitel kx
Be the first to answer 11/7/2011 3:48:58 PM • Panasonic... • Posted on Nov 07, 2011Be the first to answer
Manual for voice message recorder-
You can download the manual from the manufacturer's web site at
http://service.us.panasonic.com/OPERMANPDF/KXTG2356.PDF
8/11/2011 9:14:41 PM • Panasonic... • Answered on Aug 11, 2011
When a call comes in
your phone gets calls in and will associate the name it reads. For example if your friend JOE calls tthen the system will say Call from Joe. But if the number is unlisted or blocked the Call from Number Available message will sound. If you don't have call display the all number coming in are imarked as Number Available.
8/9/2011 1:00:25 AM • Panasonic... • Answered on Aug 09, 2011
2answers
My phone says -no line from base -move closer - I
If the handset works for a while after returning it to the base, I would replace the battery, here is a link where I bought a battery for my Panasonic cordless phone http://www.emtcompany.com/panasonic-kx-tg2356-battery-3-6v-830-mah/pcf104.html
4/4/2011 1:22:51 PM • Panasonic... • Answered on Apr 04, 2011
WHEN A CALL COMES IN
The answer to this is quite involved. You must first prepare the answering system, decide if you want to record your own personal greeting, how long you want the actual recording time to be and number of rings before the machine answers and then set the system to answer on.
This whole process is quite involved and takes up several pages which is impractical to reproduce here, so rather than copying it all here I am providing a link to the manual for this phone.
Please refer to pages 20 to 24 inclusive and 52 to 56 inclusive regarding how to set up the answering machine and how to listen to playback of messages. Link is below;
Thanks for using FixYa. Please remember to leave a vote for the solution.
12/12/2010 3:22:22 AM • Panasonic... • Answered on Dec 12, 2010
0answers
No dial tone on hand set battery is new lights up
Make sure your connection to the phone jack is secure.
Use another wired phone to make sure connection is good to your phone.
Secure connection in back of phone, and plug it in. The base MUST have power to transmit the signal to the handset even if the handset has a fresh charge.
Although the handset is normally linked to the bases, check to make sure via the instructions. To determine if the base recognizes the handset, press the "LOCATE HANDSET" button.
If the hadset responds, the links is there.
Hope this helps
good luck and don't forget to vote!!!
9/27/2010 8:58:31 PM • Panasonic... • Answered on Sep 27, 2010
Have changed battery but the phone dies out after
I just called Panasonic and they said that this phone is discontinued. I questioned why and got no answer except: Sorry, have a nice day.
8/5/2010 9:32:28 PM • Panasonic... • Answered on Aug 05, 2010
2answers
Panasonic KX-TG2356 Cordless Phone key pad
Open the hand set by Removing battery, remove 2 screws under battery, carefully open handset casing by prying open with thin bladed screwdriver, remove pc board by removing 3 retaining screws, on opposite side of pc you will see contacts for handset buttons clean with eraser and reassemble handset.
4/4/2010 7:42:28 PM • Panasonic... • Answered on Apr 04, 2010
Panasonic KX-TG2356 Cordless Phone Logo
52 questions posted
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Lands Phones
Most Popular Question
phone says no line from base move closer
  • Lands Phones
