20 Most Recent
RTO 50cc Moped Scooter Questions & Answers
2002 roketa 50cc will not start
If your 2002 Roketa 50cc scooter will not start, there are a few potential causes to consider:
- Fuel issues: Make sure you have enough fuel in the tank and that the fuel is fresh. Also, check the fuel filter to ensure it's not clogged.
- Air filter: A clogged air filter can restrict airflow to the engine, making it difficult to start. Check the air filter and clean or replace it if necessary.
- Spark plug: A fouled or worn spark plug can prevent the engine from starting. Check the spark plug and replace it if necessary.
- Battery: A weak or dead battery can prevent the engine from starting. Check the battery and charge or replace it if necessary.
- Compression: Low compression can cause the engine to not start.
- Starter: If the starter motor is not functioning properly, the engine will not turn over.
- Choke: Make sure that the choke is working properly.
It's possible that one or more of these issues may be causing the problem. It is recommend to check the owner's manual for troubleshooting and further guidance. If the problem persist, it is best to take it to a qualified mechanic for diagnosis and repair.
Longjia 50cc repair manual moped
I've not found a manual for specifically this model, but there's quite a good Haynes book; "Chinese Tiwanese & Korean Scooters" (4768) covers the similarities and differences between many of the the various GY6 based scooters on the market - all you need is a little commom sense to identify similarities and differences on your specific scooter.
Vespa et2 manual
unlock the steering with a key as it is locked in a position to prevent theft.
