20 Most Recent
RTO Mini Quads Questions & Answers
50cc Apache quad. Started the first few times with the kick start and now it has suddenly stopped starting
There could be a few different reasons why your 50cc Apache quad has suddenly stopped starting after starting with the kick start a few times. Some possible causes include:
- Fuel issues: Make sure you have enough fuel in the tank and that the fuel is fresh. Also, check the fuel filter to ensure it's not clogged.
- Air filter: A clogged air filter can restrict airflow to the engine, making it difficult to start. Check the air filter and clean or replace it if necessary.
- Spark plug: A fouled or worn spark plug can prevent the engine from starting. Check the spark plug and replace it if necessary.
- Battery: A weak or dead battery can prevent the engine from starting. Check the battery and charge or replace it if necessary.
- Compression: low compression can cause the engine to not start.
- Choke: Make sure that the choke is working properly.
It's possible that one or more of these issues may be causing the problem. It is recommend to check the owner's manual for troubleshooting and further guidance. If the problem persist, it is best to take it to a qualified mechanic for diagnosis and repair.
49cc mini pocket quad wont start
if it has a kill switch make sure it is on, check that you are getting spark at the plug and have the right fuel in the motor.
Remove the air filter from the carbi and squirt some 2 stroke fuel directly into the throat of the carbi and try to start it.
hope this helps
I have a new 50 cc mini quad for my kids and its
Try changing the spark plug making sure the gap on the new plug is at recommended specs.If the plug is black when you pull it out mix gas with a little less oil but not much as if it is to lean it can burn up motor make sure gas mixtured isn't to rich if you have to mix the gas and oil together yourself.
