20 Most Recent RTO Forklift and Pallet Construction Vehicle Questions & Answers
Bleedbrakes S120XL
bleed the brakes by applying the pedal to generate pressure same as you do in a car gravity bleeding allows air back up the lines and vacuum bleeding sucks air in past the brake seals
11/11/2017 3:13:22 AM • RTO Forklift and... • Answered on Nov 11, 2017
Crown WAV 50-84 will not lower
have you tried the manual push in on the manual valve in the base below. then check the the charge on the batteries
6/1/2015 10:43:55 PM • RTO Forklift and... • Answered on Jun 01, 2015
I own a Lansing Bagnall forklift Model:
The chain that drives the reach has slipped on its sprocket.An easy fix if you know how .Just ask if you need help
5/15/2013 3:06:22 PM • RTO Forklift and... • Answered on May 15, 2013
2answers
Forklift will not run unless you pull the coil
Replace the coil and coil wire..
Have a great day !
4/9/2013 2:40:02 AM • RTO Forklift and... • Answered on Apr 09, 2013
2answers
Komatsu electric forklift with dead battery.
you can lease a battery, or battery charger if the battery is still good
4/1/2013 9:36:48 AM • RTO Forklift and... • Answered on Apr 01, 2013
THE CONECCTION OFF THE BATTERIES USE 4 OF 6VOLTS
your battery is bad if its using 4 volts out of 6 or your charger has went..
3/1/2011 2:08:46 AM • RTO Forklift and... • Answered on Mar 01, 2011
I have a hyster electric lift truck # e50xm-27
INTERNAL VOLTAGE BELOW 10 VOLTS CHECK CONNECTIONS
2/15/2011 10:11:47 PM • RTO Forklift and... • Answered on Feb 15, 2011
I have connected a heavy duty charger (3 phase
check on the door panel inside the charger there should be wiring and code diagram,if not you should be able to contact the charger manufacturer listed on the charger
10/6/2010 7:18:35 AM • RTO Forklift and... • Answered on Oct 06, 2010
The lift and tilt system of a forklift typically
hydrualic pump
10/6/2010 6:57:10 AM • RTO Forklift and... • Answered on Oct 06, 2010
0answers
MY 49 CC SCOOTER WONT GO OVER 10 MPH IT BOGS DOWN BACK TO IDLE
No idea, it can be varible
11/11/2019 1:24:52 AM • RTO Toys • Answered on Nov 11, 2019
RTO Forklift and Pallet Construction Vehicle Logo
29 questions posted
Top RTO Toys Experts
Jay Finke
Jay Finke
ADMIN Eric
ADMIN Eric
Jerry Ross
Jerry Ross
Are you a RTO Toy Expert? Answer questions, earn points and help others
View Most Popular
RTO Toys
  • RTO Toys
Most Popular Question
bleedbrakes s120xl
  • Toys
