20 Most Recent
Peg Perego John Deere Turf Tractor Questions & Answers
Turf
this is definitely in the wrong category
Rear tires
pop off the center caps from both rear tires with a flat head screwdriver, and then remove the push nut washers by bending them with a pliers and removing them (keep in mind this will ruin the existing push nuts and replacements will need to be purchase from ebay or somewhere similar) then slide the tire off of the axle and replace (do not remove the axle cause there are spacers inside the vehicle that will fall out of place)
One rear tire not turning
sounds like a bad motor, swap the motor wires between the two sides and see if the problem persists if it does its the shifter switch, if it doesn't its the motor
