20 Most Recent
RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2 Questions & Answers
MF Tractor 265 diesel engine fuel problems.
I ran into the same problem and found the line to the tank was clogged, take your line loose and see if your fuel flows freely if not blow some air from a compressor back up the line and into the tank. Hope this helpls
3/30/2022 9:07:01 AM •
RTO...
Answered
on Mar 30, 2022
TO-30 quit running, puff of smoke from electrical? Won't turn over
It is possible to have the solenoid go bad but not while the tractor is running as it is only used to engage the starter. It sounds like the wires to the starter is shorted out. I would run a hot wire to the solenoid from the battery to the solenoid and see if it will start. Just be sure everything is grounded. If the ground cable on the battery is ok you should not have a problem with running a hot wire to the solenoid. Just touch the hot wire to the starter and then release it when the starter engages. Hope this helps.
4/16/2017 11:42:59 PM •
RTO...
Answered
on Apr 16, 2017
