20 Most Recent Ford "c" Cabover Semi Tractor-disalvo Trucking - White Questions & Answers
2answers
Transmission wont shift from high side too low side/ fuller 9speed
Have you Checked your Vacuum Line ? This is the most common issue with the High / Low Problems,....
11/11/2014 2:33:27 PM • Ford "c" Cabover... • Answered on Nov 11, 2014
0answers
0answers
Why the high / low shifter on a eaton/fuller won't shift right?
Check the Air pressure regulator, it should be putting out 62.5 psi
10/8/2013 1:19:01 AM • Ford "c" Cabover... • Answered on Oct 08, 2013
What tool is needed to remove flywheel from the engine of a 8n ford tractor
s://www.youtube.com/watch?v=3kAKRTZHTJ8
3/13/2019 7:34:42 PM • Ford Toys • Answered on Mar 13, 2019
My 8N ford won't start, just back fires out exhaust?
sounds like a timing or point adjustment problem .. Mission Statement
7/13/2018 1:14:02 PM • Ford Toys • Answered on Jul 13, 2018
My 8n ford when placed in high gear wants to cut off. Are the spark plugs the problem?
Plugs would probably not be my first check, though fouled plugs or more likely points may be contributing. I would first check fuel and air screens and filters. Be sure you have clean fuel coming through. Here is an excellent resource if you haven't found it already .... Mission Statement
7/13/2018 1:10:42 PM • Ford Toys • Answered on Jul 13, 2018
2answers
What year is an 8n Ford tractor serial # 202715?
complete list http://ford8n.com/ford-tractor-serial-numbers.html Ford 8N Tractors series Serial Numbers
12/4/2017 1:13:44 PM • Ford Toys • Answered on Dec 04, 2017
0answers
How to download, free, wiring diagram for 8N Ford tractor?
It depends what format that it's in. If it's in a pdf format, adobe acrobat reader will do it for you and the program is free. If it's in another, let me know and I will direct you.
5/28/2017 3:31:37 PM • Ford Toys • Answered on May 28, 2017
Ford 9030 service manual
3/18/2016 1:50:44 PM • Ford Toys • Answered on Mar 18, 2016
Ford "c" Cabover Semi Tractor-disalvo Trucking - White Logo
Popular Tags
9 questions posted
Top Ford Toys Experts
Kardoc
Paul Katynski
Paul Katynski
Are you a Ford Toy Expert? Answer questions, earn points and help others
View Most Popular
Ford Toys
  • Ford Toys
Most Popular Question
high low shifter eaton fuller shift
  • Toys
