20 Most Recent
Panasonic KX-T7431 Corded Phone Questions & Answers
How to display time instead of Ring Off?
You can search for desired items by using the Jog Dial on the corresponding display menu. Rotate the Jog Dial in either direction as desired. The items will be displayed as follows. There will be seven displays.
4/2/2015 8:00:41 PM •
Panasonic...
Answered
on Apr 02, 2015
HOW IS THE CLOCK TIME CHANGED ON A KX-T7431 PHONE
From the phone connected to the first jack (usually ext 101) press PROGRAM and dial **1234. If it's successful, you'll see SYS PGM? or similar language. Dial 000 and press SP PH. You should see the date. Press FWD until the time displays. Key in the new time and press STORE to save.
PROGRAM or pick up the handset and drop it back down will get you out of programming.
Carl
10/16/2014 10:19:14 PM •
Panasonic...
Answered
on Oct 16, 2014
Problem with extension and voicemail
1. Can be done but you have to have installer access to the system. You could also move the extensions at the phone system.
2. Is his call forwarding set (720x 165 #)? 720 sets forwarding for both intercom and outside calls.
1/17/2014 11:16:36 PM •
Panasonic...
Answered
on Jan 17, 2014
