20 Most Recent Max Heli- Axe CX Micro Electric Rc Mini Helicopter Body Colors Vary Questions & Answers
3answers
Heli max hicro helicopter just keeps spinning in circles
Spinning is caused by one of the main propellers rotating faster than the other. If both propellers are secured tightly to their drive shafts, the spin control knob on the remote control can be used to stop the spin. However, if one prop is slipping with respect to the other, the spin control knob will not fix the problem.
I've found that the set screws holding the propellers to the drive shafts tend to loosen after a while. If one prop is a bit loose and the other is tight, the relative slippage will cause the helicopter to spin.
To check, turn off helicopter power and manually rotate each propeller separately, watching the nylon gears in the body. If the propeller is moving and its drive shaft gear isn't, the propeller is slipping because its set screws are not applying enough pressure on the propeller's drive shaft.
Carefully tighten the set screw and the problem should be fixed. DON'T OVERTIGHTEN, or the plastic threads for the set screw will be stripped and the propeller assembly will be ruined.
4/23/2010 3:46:03 PM • Max Heli- Axe CX... • Answered on Apr 23, 2010
I need a cable assembly instruction manual for a york mega max 3001
https://www.google.com/search?q=york+mega+max+3001&oq=york+mega+max+3001&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
11/30/2020 4:26:11 PM • Max Toys • Answered on Nov 30, 2020
2answers
Do you have any good craft ideas for kids under six?
I was able to find you this website with all kinds of great craft kits for pre-kindergarteners.
3/26/2024 11:30:29 AM • Toys • Answered on Mar 26, 2024
Hi I've got a babyweaver
Sounds like you are missing the central support rod or bar that connects the Babyweaver swinging crib to the stand, providing stability and support for the crib. This component is crucial for maintaining the structural integrity of the crib and ensuring safe usage. Here are some steps you can take to address the missing part: 1. Contact the Manufacturer: - Reach out to Babyweaver or the manufacturer of the swinging crib to inquire about obtaining a replacement central support rod. - Provide them with details about the missing part and the specific model of the swinging crib to ensure you receive the correct component. 2. Check for Spare Parts: - Check if the swinging crib came with a user manual or assembly instructions that may have information about spare parts or replacement components. - Look for any contact information provided for customer support or spare parts inquiries. 3. Online Search: - Conduct an online search using keywords such as "Babyweaver swinging crib central support rod" or "Babyweaver crib replacement parts" to see if you can find the specific part for purchase. - Explore baby product retailers, online marketplaces, and specialty stores that offer replacement parts for nursery furniture. 4. Local Retailers: - Visit local baby product stores or furniture stores that carry nursery items. - Bring the existing part (if you have one side of the support rod) to help them identify and match the missing component. 5. Custom Fabrication: - If you are unable to find a suitable replacement part, consider contacting a metal fabrication shop or a carpenter who may be able to custom-make a central support rod that fits your Babyweaver swinging crib. - Provide them with measurements and details about the required specifications for the part.
3/22/2024 3:29:32 AM • Toys • Answered on Mar 22, 2024
I have a new model teddy ruxpin and my 2 year old daughter tripped and dropped him. His lights all come on but his app and sound are not working
It sounds like the drop may have caused some internal damage to the electronics or wiring of the Teddy Ruxpin toy. Here are some steps you can take to try and troubleshoot the issue:
  1. Restart the Toy: Sometimes a simple restart can resolve minor issues. Try turning off the toy completely, including any power switches or buttons, and then turning it back on again after a few moments.
  2. Check Battery Compartment: Ensure that the batteries are properly inserted and making good contact with the terminals inside the battery compartment. If the drop caused any displacement of the batteries, it might affect the toy's functionality.
  3. Inspect for Physical Damage: Carefully examine the exterior of the toy for any signs of physical damage, such as cracks, dents, or loose parts. If there's visible damage, it may indicate internal damage as well.
  4. Test with Different Devices: If the Teddy Ruxpin toy connects to a separate app or device for sound playback, try connecting it to a different device to see if the issue persists. This can help determine if the problem lies with the toy or the connected device.
  5. Contact Customer Support: If none of the above steps resolve the issue, it's possible that the drop caused internal damage to the toy's electronics or wiring. In this case, you may need to contact the manufacturer's customer support for assistance. They may be able to provide further troubleshooting steps or offer a repair or replacement option.
Keep in mind that since the toy is relatively new, it may still be under warranty, which could cover repairs or replacements for damage caused by accidents like drops. Be sure to check the warranty information or contact the manufacturer for guidance on warranty coverage.
3/21/2024 2:25:15 PM • Toys • Answered on Mar 21, 2024
3answers
I heard about a pretend toy store game to play with children. Does anyone know how it works? I am not so good at making games up.
This game is a great one to play with kids on a wet afternoon stuck indoors. Basically use their toys to turn an area of the house into a toy store. Get the kids involved in choosing the games they would like to 'sell'. Write prices lists and stick them somewhere that the kids can see and reach ie Lego sets - $4, Dolls - $2
If you don't have any pretend money, you can make your own with the kids, then divide up the tasks and let them enjoy many hours of pretend shopping.
3/8/2024 4:48:19 AM • Toys • Answered on Mar 08, 2024
How to get mobigo sim lock ME code
I would contact your service provider for the code.
3/5/2024 10:20:49 PM • Toys • Answered on Mar 05, 2024
Spalding 17086 dartboard manual please.
Question edited for clarity and spelling of the maker, 'Spaulding'.
Manuals Page
Spalding.com https://www.spalding.com > customer-service > info > m... Systems Manual Finder. You will need your model number to locate the correct manual. Please follow the steps below or visit our interactive manual finder. ..
2/27/2024 9:21:22 PM • Toys • Answered on Feb 27, 2024
Fisher-Price J7485 T-Rex stopped moving
Check Batteries: Ensure that the batteries are properly inserted and have sufficient charge. Sometimes, a low battery can cause the toy to stop functioning. Switch On/Off: Confirm that the toy is switched on. Some toys have an on/off switch or button that might accidentally get turned off. Connections and Wires: Inspect the wires and connections inside the toy. Loose wires or faulty connections can lead to malfunction. Obstructions: Look for any obstructions or debris that might be preventing the T-Rex's movement. Clear any blockages. Reset: If there's a reset button, try pressing it. This can sometimes resolve minor issues. Contact Customer Support: If none of the above steps work, consider reaching out to Fisher-Price customer support as below. https://service.mattel.com/us/ContactUs.aspx
2/22/2024 2:51:59 PM • Toys • Answered on Feb 22, 2024
Fidelity HM Remote Control RFD001 - RC Helicopter. How to charge rfd001 helicopter please?
You use a USB charger lead to charge the battery in the helicopter. The controller takes 6 x AA batteries. https://rc-today.ru/UserFiles/Image/Instructions/-S929.pdf https://www.google.com/search?q=rfd001+helicopter+charging+lead ..
2/1/2024 4:35:42 PM • Toys • Answered on Feb 01, 2024
Need Play 'N Learn Computer 420 schematic of inside gears or even a picture of the insides. My grandson dropped it and the gears fell out inside the casing. Thank you.
It is too old (1970s) for that data to be on the Internet. There is one for sale on eBay, buy it and carefully look inside. https://www.google.com/search?q=Need+Play+%27N+Learn+Computer+420 ..
2/1/2024 3:17:56 AM • Toys • Answered on Feb 01, 2024
2answers
Can I fix an error on my orthofix 2212 it shows
Why are you guys giving answers to fix a printer when the OP is asking how to clear the error code on an orthofix bone growth stimulator used to help the bones fuse together after back surgery... I'll give my best guess as I am having the same issue. They are set to last a certain amount of time and designed to stop working after that set time. In my case I got the device, postponed my surgery and my orthofix wouldn't work after I actually had the surgery.. 2nd best guess would be a battery issue because I can charge mine fully, turn it on for about 10 min, put ot back on the charger and it flashes all 4 bars like its completely dead.. but there is a number you can call that can help you more than I can, 18005354492
1/17/2024 9:11:13 PM • Toys • Answered on Jan 17, 2024
Where can i find the rules for the carbles game
https://www.thecarblesshop.com/general-6
1/15/2024 6:14:58 PM • Toys • Answered on Jan 15, 2024
3answers
How ca i overcome my
Tried and tested solutions.
Go out and take deep breath and in your mind say 'I want to get rid of this bad habit"
1/4/2024 6:43:12 PM • Toys • Answered on Jan 04, 2024
Where can I get a manual for a holiday experience animated train set?
Not much here but this may help; https://www.ehow.com/how_8084827_instructions-express-animated-train-set.html
12/31/2023 3:45:01 PM • Toys • Answered on Dec 31, 2023
Dept 56 Snow Village Rock Point Lighthouse #56.55397. Can you change the bulb that spins on it?
Question edited for clarity. Question moved from Television category to Toys. Department 56 sell bulbs. The unit was retired in 2006. https://www.google.com/search?q=dept+56+rock+point+lighthouse+56.55397+replace+light ..
12/29/2023 7:20:55 PM • Toys • Answered on Dec 29, 2023
I have a Telco Santa express train that won't go into spin or take off mode
It is a vintage item and not much known about it. https://www.google.com/search?q=Telco+Santa+express+train Most repairs can be undertaken at a local model shop. If they don't do it, they will know someone that does. ..
12/29/2023 1:17:05 AM • Toys • Answered on Dec 29, 2023
How to reset my nsfas password because u don't remember it anymore
If you want to reset your nsfas password, here is what you should do.
  1. Go to www.nsfas.org.za
  2. Click nsfas account
  3. Click 'forgot password'
  4. Type in your ID number
  5. Choose one of the following options:
    • I can't remember my username
    • I can't remember my password
    • I can't remember my username and password
  6. Choose the relevant option
  7. Click 'submit'
  8. A One Time Pin (OTP) will be sent to you via SMS and email to the cellphone number and email you provided
  9. Check your cellphone or email for the OTP. This OTP is only valid for 24 hours
  10. Type the OTP number in the provided block
  11. Click 'submit'
  12. A link to reset your login details will be sent to you via email and SMS
  13. Click on the link that was received through SMS or email
  14. Follow the reset process
  15. Create a new password by following the instruction on the screen
  16. Click 'submit'
And you're done. You should now have a new password set on your nsfas account.
12/25/2023 1:31:19 PM • Toys • Answered on Dec 25, 2023
Max Heli- Axe CX Micro Electric Rc Mini Helicopter Body Colors Vary Logo
5 questions posted
Top Max Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Max Toy Expert? Answer questions, earn points and help others
View Most Popular
Max Toys
  • Max Toys
Most Popular Question
heli max hicro helicopter just keeps
  • Toys
