20 Most Recent Seiko SGF204 Wrist Watch Questions & Answers
3answers
Setting Date. Seiko SGF204 (w/ 7N43 Band) French & English Days.
If you pull out the stem 1/2 way, you set the date one direction, and the day the other. If you pull it out all the way, it moves the hands and sets the time.
11/16/2022 10:13:43 PM • Seiko SGF204... • Answered on Nov 16, 2022
Need battery number for seiko watch 7N43
Eugene, SR920W battery, nice watch, I would just take it into a local jewelers and have them replace battery, would not be that expensive and save you the hassle. Check the attached links,instruction and guides, Good luck "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." 2PC Energizer 371 370 SR920W SR920SW Silver Oxide Battery Energizer Batteries 371 370 SR920W SR920SW Silver Oxide Watch Battery On... https://www.seikowatches.com/support/ib/pdf/Analogue_E.pdf
8/4/2016 8:21:04 PM • Seiko SGF204... • Answered on Aug 04, 2016
2answers
Need battery # Seiko 7N43 9070
You can purchase your battery from amazon, take a look here: Amazon com SR920SW battery (SR920SW battery is what you need). I hope this was helpful. Cheers
12/7/2014 8:38:03 PM • Seiko SGF204... • Answered on Dec 07, 2014
Remove crystal of SNZH57
This isn't really a job for the DIY.. Best to take to professional
10/2/2013 1:37:03 PM • Seiko SGF204... • Answered on Oct 02, 2013
What battery goes in the 7n43-9070
SR927Sw
9/1/2012 2:32:48 PM • Seiko SGF204... • Answered on Sep 01, 2012
0answers
How do you take the
There is a special tool required that will help you to unscrew the case back on the watch. I found mine at a local WalMart, in the watch battery section of the jewelry area, for $5. This tool will work on other brands, as well, with the same type of case back.
2/28/2011 3:30:58 PM • Seiko SGF204... • Answered on Feb 28, 2011
Seiko SGF204 second hand hesitates or jumps a
When the watch jumps a second or seems to stop then tick twice, it indicates that the battery is low. You will need to take your watch to have the battery replaced.
2/28/2011 4:58:21 AM • Seiko SGF204... • Answered on Feb 28, 2011
I was told that the circuit boark is defective. I
Hi...The circuit Board my be defective if an old battery was left in to long ...As for not beeing supported any longer this watch is still beeing sold and is less than 20 years old it should still be supported a solution would be to replace the battery and gently clean the circut board with a dry soft clean tooth brush mainly the areas where the battery is placed
1/30/2011 10:11:19 PM • Seiko SGF204... • Answered on Jan 30, 2011
Adjusting day/date on a self winding Seiko, 7S2GB
mcdevito75 here, Your stem has 1 positions to set the date easily without haveing to cycle the watch 60 times. First pull the stem out to set the day, set the day 1 day before the day you want, next, push the crown back in, NOW! Slip a finger nail just under the crown from the back as there is more room, it may take some practice so be patiernt and gently, gently lift the crown to it"s first position, once in it"s first position turn the stem and see the DATE change, set the DATE to 1 DATE before the DATE you want, NOW pull the stem out to set the day date and time of day. Your watch is set and the day date will change on time, a little past mid nite.
7/23/2010 7:47:31 PM • Seiko SGF204... • Answered on Jul 23, 2010
The rubber band broke on my seiko dive
mcdevito75 here, Best Bet, you may need a special tool to remove and replace the SPRING BARS (PINS) that hold the band onto the watch, then you may even need new spring Bars, (pins) to re-attach the band to rthe watch. BEST BET, look for a small watch repair shop in your area to change the band.
7/21/2010 9:08:34 PM • Seiko SGF204... • Answered on Jul 21, 2010
What did this watch cost - new?
Depends on a lot, What part of the world it was sold in, who sold it etc, etc.
6/14/2010 12:53:22 PM • Seiko SGF204... • Answered on Jun 14, 2010
Watch setting instructions SEIKO 7N43 8A39 "A1"
If you are still wondering about this, pull the knob out to the first click. turn one way to set day, turn the other way to set date. Pull out further to set time.
3/9/2010 3:04:07 AM • Seiko SGF204... • Answered on Mar 09, 2010
Early 90's SEIKO 7N43 8A39
The 7N43 movements are readily available for less than $25 and any jeweler can install them. I own the same watch myself and really like it but after 14 years the date wheel is slipping and its cheaper to replace the whole movement than fix it.
I'd try a different jeweler as obviously yours is trying to sell you a new watch!
1/4/2010 4:20:56 PM • Seiko SGF204... • Answered on Jan 04, 2010
Instructions for a Seiko Alarm Chronograph Watch A158-5040A?
Question moved from Lands Phones category.
SEIKO - A158 5040
Digital Watch Library http://www.digitalwatchlibrary.com > DWL > seiko-a1... SEIKO - A158 5040 - Digital. Released in 1978 Vintage Digital Watch - Brought to you courtesy of digital-watch.com.
SEIKO QUARTZ Cal. A159 Alarm Chronograph
My Retro Watches https://myretrowatches.co.uk > uploads > 2020/09 The A158 Alarm Chronograph model can be set to give a time signal ... QUARTZ. ALARM-CHRONOGRAPH. START/STOP. DATE/SELECT. STOP-ALARM. WATCH SET TIME SET LAP STOP ... 3 pages Missing: 5040A ‎' Show results with: 5040A
Instruction ' Seiko Watch Corporation
SEIKO WATCH https://www.seikowatches.com > customerservice > ins... Seiko is one of the few fully integrated watch manufactures. We design and develop our own movements using leading-edge technology.
11/25/2023 6:10:48 PM • Seiko Watches • Answered on Nov 25, 2023
Seiko SGF204 Wrist Watch Logo
27 questions posted
Top Seiko Watches Experts
Paul Bade
Ngoro
Are you a Seiko Watch Expert? Answer questions, earn points and help others
View Most Popular
Seiko Watches
  • Seiko Watches
Most Popular Question
need battery seiko 7n43 9070
  • Watches
