20 Most Recent
Harley Davidson 2007 Harley-Davidson FLHX Street Glide Questions & Answers
I just purchased a 2007 Street Glide (traded a
the touring models are going to vibrate or more so shake at and idle more than your softail.the one major difference in your twin cam "B" engine and twin cam 96" A engine is that the softail is counter balanced in the crank case and is also a solid mount engine. straight engine to frame.these two counter balancer's are chain driven off of the crank. the street glide has three rubber mounts on it, one being in the front where the wish bone or down tubes turn inder the bike and two in cleave blocks that are alighned by small pins to be located in the correct position the swing arm also uses these in mounting the swing arm. so you will notice at around 75 mph to 80 mph you may get a "rider known death wobble" (just slow down) there are after market braces in all ranges of price to solve that problem. the more expensive the better it will last and work.
I have a 2007 harley davidon
dont know how many miles or how well you maintain it,but its a possibility of the check valve in the camsupport plate sticking though thats more common in 88 inch motors,how well do you trust your mechanic shop,they should be able to pinpoint what happened,however if your not sure of your shop,I have two retorical questions,how long after your last service did it happen,and did you check to see that there was oil in it after it quit,they wouldnt be the first to 'forget"to put oil in it or maybe the drain plug came loose, thing is only the guy that tears it down will know for sure,but you definatly lost oil pressure, your idiot light should have been glowing
My 1995 FLHTC loses spark
check the voltage at the spark plug.also check the reading of the coil from which the spark plug gets power.the reading should be exact 12 volt,.if its less or high then its fault in the coil pack.that has to be checked and replaced.get this reading checked by the local repair garage .
This will help. Thanks please keep
updated.please do rate the solution positively .thank you for using fixya
I need to know the torque settings
whats most important is red locktite,and dont overtighten clutchpack 50ftlbs clutch, compensator they've changed a few times through the different years but75ftlbs should do it loctite loctite loctite
Lights dim when rpms up
Start by checking you're stator output, Put a meter on it in VAC ( Volts AC ) on the 2 wires coming out of the case ( on the left side of the bike ) run the bike General rule of thumb is 25 VAC for every 3000 rpm. ex: 25 @ 3000, 50 @ 4000, 75 @ 3000. On the older bikes as long as you're around 65 and up @ 3000 you should be good. I’m happy to assist further over the phone at
https://www.6ya.com/expert/robert_5bac37c3cb991fdb
Hi I've got a babyweaver
Sounds like you are missing the central support rod or bar that connects the Babyweaver swinging crib to the stand, providing stability and support for the crib. This component is crucial for maintaining the structural integrity of the crib and ensuring safe usage. Here are some steps you can take to address the missing part:
1. Contact the Manufacturer:
- Reach out to Babyweaver or the manufacturer of the swinging crib to inquire about obtaining a replacement central support rod.
- Provide them with details about the missing part and the specific model of the swinging crib to ensure you receive the correct component.
2. Check for Spare Parts:
- Check if the swinging crib came with a user manual or assembly instructions that may have information about spare parts or replacement components.
- Look for any contact information provided for customer support or spare parts inquiries.
3. Online Search:
- Conduct an online search using keywords such as "Babyweaver swinging crib central support rod" or "Babyweaver crib replacement parts" to see if you can find the specific part for purchase.
- Explore baby product retailers, online marketplaces, and specialty stores that offer replacement parts for nursery furniture.
4. Local Retailers:
- Visit local baby product stores or furniture stores that carry nursery items.
- Bring the existing part (if you have one side of the support rod) to help them identify and match the missing component.
5. Custom Fabrication:
- If you are unable to find a suitable replacement part, consider contacting a metal fabrication shop or a carpenter who may be able to custom-make a central support rod that fits your Babyweaver swinging crib.
- Provide them with measurements and details about the required specifications for the part.
3/22/2024 3:29:32 AM •
Toys
Answered
on Mar 22, 2024
I have a new model teddy ruxpin and my 2 year old daughter tripped and dropped him. His lights all come on but his app and sound are not working
It sounds like the drop may have caused some internal damage to the electronics or wiring of the Teddy Ruxpin toy. Here are some steps you can take to try and troubleshoot the issue:
- Restart the Toy: Sometimes a simple restart can resolve minor issues. Try turning off the toy completely, including any power switches or buttons, and then turning it back on again after a few moments.
- Check Battery Compartment: Ensure that the batteries are properly inserted and making good contact with the terminals inside the battery compartment. If the drop caused any displacement of the batteries, it might affect the toy's functionality.
- Inspect for Physical Damage: Carefully examine the exterior of the toy for any signs of physical damage, such as cracks, dents, or loose parts. If there's visible damage, it may indicate internal damage as well.
- Test with Different Devices: If the Teddy Ruxpin toy connects to a separate app or device for sound playback, try connecting it to a different device to see if the issue persists. This can help determine if the problem lies with the toy or the connected device.
- Contact Customer Support: If none of the above steps resolve the issue, it's possible that the drop caused internal damage to the toy's electronics or wiring. In this case, you may need to contact the manufacturer's customer support for assistance. They may be able to provide further troubleshooting steps or offer a repair or replacement option.
Keep in mind that since the toy is relatively new, it may still be under warranty, which could cover repairs or replacements for damage caused by accidents like drops. Be sure to check the warranty information or contact the manufacturer for guidance on warranty coverage.
3/21/2024 2:25:15 PM •
Toys
Answered
on Mar 21, 2024
