20 Most Recent
Kaspersky Labs Anti-Virus 2009 for PC Questions & Answers
Unable to install Kaspersky Anti Virus because of error code 403
ok is kaspery the only antivirus you have on you pc ok i no i no the reaon it cased and error is because i the software may be corrupt and did you get it from its web site or another see the error code came from the bios ok maybe the computer has a problem whith the antivirus ok is this the first antivirus software you have ever used so you need to remove it and if you want to use it agan make sure you down load it from the kaspery web site what wer you doing when this happened cant give more imformation unless i no what you were dong or what caused this see i never use kaspery i use antivira antivirus no it is possible that kaspery is betat software and beta software dcause problems all i can say is try another antivirus software and see if you get this error again then if you do i no the culprit
Kaspersky Security 2009 AntiVirus can not install.....
Hi
first of all make sure that your account in the computer is the one that has administrative rights on it
try checking the minimum requirements and the platform as specified on the kaspersky software.
if you want i can help you install the s/w
you may reach me on my email
Sir i need a free activation code to activate
Yes, you need to purchase.
Another product that has a free service is Avast.
And searching for free activation codes and serial numbers is a pretty good way of getting computer viruses and the like.
Good luck.
Geeksquad com
Although it is the 2009 version of Kapersky, it was upgraded to the latest version upon installation. The subscription which came with your computer is good for one year and you will be receiving renewal notices as the end of the subscription nears. Thus, if the one year license was activated in Jan 2013, it would have expired eight months ago. Unless you have activated another security or anti-virus program, your computer is unprotected and you are in danger of not only having your personal data compromised, but you are also in danger of having your computer taken over by viruses and malware.
How to remove shortcut virus
Download Kaspersky Removal tool into your system and then run a complete scan of your PC.
If you find the virus or Worm, simply just follow the recommendation action and thick mark for apply to all objects.
http://www.gokhiel.com/2010/08/how-to-remove-virus-shortcut-folder.html
Gateway computer/Trying to install Kaspersky!!
hi
if the PC/laptop is part of a corporate roup then you'll have to take the assistence of the systems guys
but
if the PC/Laptop is self owned then please add the user account tht u r using to the administrators group and that should solve your problem
right click on my computer
select manage
expand local users and groups
select groups
on the right panel select right click on administrators
select add
in the box type ur user account and click on check names
once it is confirmed select ok and close the windows
now try installation again
hope it helped
cheers
PS: if it has helped you in any lil way pls rate it, thanks
Trojan
Try Malwarebytes to remove trojans from the computer.
Malwarebytes is a malware scanner and remover which can be installed and used with antivirus software.
Virus
The best way to remove virus from your Laptop is :-
Step 1. Download free version of Malewarebytes from http://www.malwarebytes.org/
Step 2 . Install it and update it from update tag >> check for updates.
Step 3. After that go to tag scanner and perform full scan.
Step 4. When scan complete click on show result and then click on remove selected.
Step 5. After removal it will ask you to restart your computer. Restart once.
And enjoy Virus/Spyware free environment.
iTechGuru
