20 Most Recent
Seiko SKA192 Wrist Watch Questions & Answers
Seiko Kinetic that doesn't work
This watch does not have a battery, but
has a capacitor which is rechargable.
It is not taking a charge, and needs to
be replaced. You should take it to a store
with a watchmaker ON THE PREMISES. Or you
could send it to:
www.bscwatchrepair.com
Hi, I am a seiko
If your watch stopped working while changing the time it can be for a couple of reason . One is i never set the watch between the hours of 11 pm and 4 am or else your movement can be damaged. The main reason is usually that the watch crown was not pushed all the way in to the first set . If the watch crown and stem is pulled out and not in the start position the watch will not run. Also after setting time you might need to reengage the watch by pressing on the jumper buttons on the top side of the crown they look like push buttons.
My Kinetic watch stopped working.
I highly suspect and probably you also suspect that the energy storage capacitor needs to be replaced. My experience in working on these is that they are only good for about 3-4 years. I only replace with a new Seiko Lithum Ion battery. Check
www.timelywatchrepair.com
How can I turn off the alarm on my Seiko quartz alarm
TO CANCEL THE ALARM TIME YOU HAVE SET ;
1.Pull out the crown to the first click, and press and hold button “B” until the alarm hands stop to indicate the current time.
2. Push the crown back in to the normal position.
