20 Most Recent Eureka Sanitaire S670 Bagged Upright Vacuum Questions & Answers
Eureka Model AS1104. left wheel doesn't turn, it's locked, any ideas?65
Question moved from Cars and trucks category. Remove the base plate and remove the wheels and axle. Remove the hair and threads that was causing the wheel to lock up. You will need to use a box cutter or similar to remove the debris. Add a couple of drops of light machine oil and reassemble. https://www.google.com/search?q=Eureka+Model+AS1104+wheel+not+turning ..
4/16/2024 5:29:12 PM • Eureka Vacuums • Answered on Apr 16, 2024
Eureka wide track super light vacuum brush roller not spinning.
It sounds like a break in the wiring. It would be somewhere near the hinge. https://www.google.com/search?q=Eureka+wide+track+super+light+vacuum+brush+roller+not+spinning ..
4/15/2024 10:23:25 PM • Eureka Vacuums • Answered on Apr 15, 2024
Having problems with belt staying on step saver the Boss eureka hand vacuum
This can be because you need to adjust the tension or probably the pulley is no longer aligned.
So find out if the shaft is no longer straight also if the belt requires tension.
2/16/2024 8:22:15 AM • Eureka Vacuums • Answered on Feb 16, 2024
Eureka Model AS1104. When I engage roller, it goes and stops when I'm pushing it to Vacuum. Belt Maybe??
Yes it is likely to be the belt, they stretch, go thin and then slip, create heat and get worse until they snap.. It is pretty easy to swap one out. https://www.google.com/search?q=Eureka+Model+AS1104 ..
2/9/2024 2:34:40 AM • Eureka Vacuums • Answered on Feb 09, 2024
Eureka Airspeed Upright Vacuum. Dirt not going into the dirt container, it is staying in the hose?
You have a blockage somewhere either in the hose, or in the unit. https://www.google.com/search?q=eureka+airspeed+blockages ..
8/22/2023 4:49:31 AM • Eureka Vacuums • Answered on Aug 22, 2023
Eureka 4469 Vacuum cleaner. How to change the belt on it please?
Question edited for clarity. The videos show how. Parts in the link
4469 Eureka Victory Upright
Parts Warehouse https://www.partswarehouse.com > Eureka-4469-Victo... Eureka 4469 Victory Upright Vacuum Parts, Accessories, & Repair Schematics. Free Shipping Available - PartsWarehouse. ... Belt Cap & Gasket 54376-2 ...
Eureka 4300/4400 Series Parts
EZVacuum.com https://www.ezvacuum.com > eureka-uprights-parts Bags, belt, filter, brushroll for Eureka Victory / Victory Whirlwind Upright ... 4387, 4388AT,4440, 4441, 4455, 4460, 4461, 4464, 4465, 4466, 4469, 4470, ...
4/14/2023 5:40:54 AM • Eureka Vacuums • Answered on Apr 14, 2023
Eureka model ECV2002A Vacuum. How to remove central vac cover to access motor/ board chamber?
No pictures attached so we can't 'see', but at 20 years old it is time for a new one. https://www.google.com/search?q=Eureka+ECV2002A+tear+down ..
4/5/2023 4:30:37 PM • Eureka Vacuums • Answered on Apr 05, 2023
Eureka NEU180. The height adjustment on it doesn't work?
Question edited for clarity. Try and claim on the warranty. It has 5 height adjustments. https://www.google.com/search?q=Eureka+NEU180.+Height+adjustment+on+it+doesn%27t+work ..
3/15/2023 3:55:35 PM • Eureka Vacuums • Answered on Mar 15, 2023
How is the filter placed on a eureka 4335 dx vacuum
  1. Locate the filter compartment on the vacuum. It is usually located under the dirt cup or canister.
  2. Remove the filter compartment cover by pressing the latch or pressing the button and pulling the cover off.
  3. Take the old filter out of the compartment and discard it.
  4. Place the new filter into the compartment, making sure it is properly seated.
  5. Replace the filter compartment cover by aligning it with the vacuum and pressing it into place.
Make sure to properly maintain and replace the filter as recommended in the owner's manual to ensure optimal performance of your Eureka 4335 DX vacuum.
1/4/2023 11:24:41 AM • Eureka Vacuums • Answered on Jan 04, 2023
Eureka rally 2will not turn on
damaged or failed switch -motor --wiring --or overheated motor
12/28/2022 6:31:24 PM • Eureka Vacuums • Answered on Dec 28, 2022
Eureka Boss Pro 411A has no suction?
Question edited for clarity and toss in a few CAPS. Question moved from Cars and Trucks. It has to be a blockage and on that one, either behind the brush or in the hose. https://evacuumstore.com/s-2349-411a.aspx https://www.google.com/search?q=Eureka+boss+pro+411+no+suction ....
12/15/2022 5:50:47 AM • Eureka Vacuums • Answered on Dec 15, 2022
My Eureka Mighty Mite 3670 vacuum turns on but does not suction or blow.
Nothing you have described should cause it to fail. Claim on the one year warranty irrespective of how long you have had it. What happens if you remove the hoses and turn the machine on? Does it suck from the hole in the body where the hose attaches? If it doesn't then the disc that is attached to the motor has sheared off the motor spindle. Was the stone in the bag, or did it punch a hole in the bag and meet the motor? https://www.google.com/search?q=Eureka+Mighty+Mite+3670+warranty ..
12/4/2022 4:33:31 PM • Eureka Vacuums • Answered on Dec 04, 2022
I bought a used Eureka Hotshot steamer. It gets warm , but no steam when I push the button. It also had whiteish water come out. Should I just throw it out
based on the price of a new one and no repair parts available, personally I would throw it away and mark it it up as lesson learned.
10/29/2022 2:27:16 PM • Eureka Vacuums • Answered on Oct 29, 2022
4answers
Eureka 2089 A - needs a replacement on/off switch. The company says they no longer make the part. Any ideas?
If you have the time allied electronics has extensive electronic parts or if you have a local electronics shop. Many years had an old Eureka Canister switch failed and I found a toggle switch that fit perfectly . It lasted another 7 years.
8/19/2022 9:03:55 AM • Eureka Vacuums • Answered on Aug 19, 2022
Eureka Sanitaire S670 Bagged Upright Vacuum Logo
Popular Tags
1 questions posted
Top Eureka Vacuums Experts
Mike Cairns
Mike Cairns
Jo Ri
Level 1 Expert
Alexander
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Eureka Vacuums
  • Eureka Vacuums
Most Popular Question
remove central vac cover access motor
  • Vacuums
