20 Most Recent
Encore Math Advantage Algebra II and Geometry 2.0 Full Version for PC Questions & Answers
Surface area of a rectangular prism whose length
Since the 'base' and 'top' of any prism have the same shape, the surface area can be found by
- surface area of prism = 2 * area of base + perimeter of base * H
So for the rectangular prism in your example..
- surface area = 2LW + 2(L+W)H
- = 2 * 7 * 4 + 2*(7+4)*5
- = 56 + 2 * 11 * 5
- = 56 +110
- = 166 sq cm
Hope this helps
What is the pyramid total surface formula
A pyramid has 5 sides including the base. If the base is a rectangle L long and W wide, its area is L*W.
The other sides are triangles. If the height of the pyramid is H, the triangles that are L wide at the base will have a height of the square root of half of W squared plus H squared, or SQRT((.5*W)^2+H^2) and the two that are W wide at the base will have a height of SQRT((.5*L)^2+H^2). The area of a triangle is .5*height*base, so the total surface two triangles with the same height and base is 2*.5*height*base = height*base.
So, the total surface area of a pyramid L long by W wide by H tall would be:
L*W (the area of the base)
+ L*SQRT((.5*W)^2+H^2) (the area of the 2 triangles with base L)
+ W*SQRT((.5*L)^2+H^2) (the area of the 2 triangles with base W)
Hope this is helpful!
Assuming the base of the pyramid is square ... of length B and the distance from the center of the base of the pyramid to the top of the pyramid is H
Surface area is: 2 x H x B
plus B-square (if you include the base of the pyramid)
I have windows 10 and I am using Printshop deluxe 6.0. I worked fine since it was purchased Oct 2022, all of a sudden it won't print my projects and I can no longer save them as JPRG
If PrintShop Deluxe 6.0 is no longer printing your projects and you are unable to save them as JPRG after uninstalling and reinstalling the software, there may be a few other things you can try to fix the problem:
- Check the printer settings: Make sure the printer is properly set up and connected to your device. Check the printer settings to ensure that it is set to the correct printer and that the printer is not experiencing any errors or issues.
- Check for updates: Check for updates for the software and the printer driver. Installing any available updates may fix the issue.
- Check for compatibility issues: Make sure that PrintShop Deluxe 6.0 is compatible with your version of Windows 10. If the software is not compatible, it may cause issues with printing and saving projects.
- Repair or reinstall the software: Try repairing or reinstalling the software to see if it fixes the issue. Make sure to follow the instructions provided by the manufacturer or technical support team to properly uninstall and reinstall the software.
If these steps do not help, you may need to contact Encore or a technical support team for further assistance. It is also a good idea to check the documentation or manual that came with the software for any troubleshooting tips or recommendations.
I have the 112 twelve
Please clean the discs in + manner. Meaning, take a soft cloth and rub it un-down and sideways and not in circular manner we usually do. Also clean the read/write head of the CD drive. It is the shiny blue dot. try running the discs in your friends computer to make sure they are fine and not damaged.
