20 Most Recent Canon EOS 450D Digital Camera with 18-55 Lens Questions & Answers
In the menu of my Canon 450D I am missing icons:
Why not try a settings reset and see what happens.
11/22/2017 6:32:15 PM • Canon EOS 450D... • Answered on Nov 22, 2017
The kit lens has stopped auto focussing all together, just makes a noise every now and then.
Two possible reasons ... A: the ribbon cable which runs from the rear mount contacts to the mid barrel has either cracked or broken (this eventually happens with continued zooming at some point in its lifetime) B: the focussing gear cog has small particle such as sand or broken plastic debris which prevents auto from fixing to focus point. Solution is to try using a blower from rear at full extension to see if it is debris ...or inspect ribbon cable.these are readily available on eBay as replacement spares.
6/6/2015 3:05:53 PM • Canon EOS 450D... • Answered on Jun 06, 2015
I have been asking for help on my question is
The non-functioning of the camera can be a fault in the shutter, zoom or auto focus sections and may be due to the failure of the Main control system or the drive. A simple was is to reset and we can try by removing the battery and card for some time. Now replace only the battery and while switching power ON, tap the lens hood on the palm of your hands so as to disengage any dirt or mechanism being struck. You can spray a degreasing spray on the lens hood sides and also assist the lens as it tries to come out, attempt to pull it outslowly while powering ON the camera. Also in some cases you can slid a thin film/paper on the lens hood sides to wipe out any dirt.
Tips to open and check for common faults: http://www.youtube.com/watch?v=v2Mj3Qp3xYU&feature=related Use some air to blow between the lenses to dislodge any sand particles struck inside. Unless you are familiar with handling of small devices must you try and open. If so check the voltage on the motor drive check the auto focus and Zoom drives, it must be free with manual movement. If jammed the motor can be removed and released. If none of these works then you can think of taking consensus with the service centre.Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
10/26/2011 2:18:02 PM • Canon EOS 450D... • Answered on Oct 26, 2011
My Canon 450D just stopped taking pictures when I
The non-functioning of the camera can be a fault in the shutter, zoom or auto focus sections and may be due to the failure of the Main control system or the drive. A simple was is to reset and we can try by removing the battery and card for some time. Now replace only the battery and while switching power ON, tap the lens hood on the palm of your hands so as to disengage any dirt or mechanism being struck. You can spray a degreasing spray on the lens hood sides and also assist the lens as it tries to come out, attempt to pull it out slowly while powering ON the camera. Also in some cases you can slid a thin film/paper on the lens hood sides to wipe out any dirt.
10/26/2011 2:15:25 PM • Canon EOS 450D... • Answered on Oct 26, 2011
My shutter won't fire using
I could be that your lens isn't focusing. If the Auto focus can't find something to focus on the shutter won't fire. If you are shooting in low light sometimes it has trouble try shooting something that is well lit. also your auto focus point may be somewhere other than the center. there is a button on the top of your camera that looks like this [ ][ ] [ ] [ ]More or less that will switch where your focus point is. If you look in the view finder and see a red dot when you push on the shutter button that is your focus point. push the above button until the red dot is in the centre. that may fix your problem.
7/26/2011 6:38:26 PM • Canon EOS 450D... • Answered on Jul 26, 2011
EOS 450D/18-55 IS, problems with
I had a similar focus problem with a Tamron 70-300 for canon. What can i tell you is that if you o not have experience in this domain you should NOT disassemble the lens because you will have a very hard time to put it back together. Also, it's very hard to allign all the glass lens inside and you may end up in making it worse.
As I see this, you have 2 options:
Either you learn using the camera in Manual Focus mode, which is not a bad idea, in time you cn become faster than the AF :)
or
you can try to find a shop that sells cameras, they may direct you to a service, it does not have to be canon but must be a person with a technical background in cameras and such.
Regards,
katharsys_i
3/7/2011 8:34:50 AM • Canon EOS 450D... • Answered on Mar 07, 2011
Yes I have the same
Check Canon's site at http://web.canon.jp/imaging/eosd/firm-e/eosdigital4/firmware.html to see if you needto update your firmware.
12/28/2010 3:38:57 PM • Canon EOS 450D... • Answered on Dec 28, 2010
The built-in flash on my Canon EOS 450D camera won't pop-up
Had the same issue and just tried this....and it worls [PS dont use the littel plastic hotshoe cover as this keeps the microswitch depressed]
If you manually 'help' the flash to open and it doesn't pop; the microswitch under the rails of your hotshoe is probably stuck in the down position as mine was. I used a toothpick top pop it up and it works now!
11/16/2010 10:07:54 PM • Canon EOS 450D... • Answered on Nov 16, 2010
The autofocus don't work anymore
Clean the contacts on the camera body and lens where they meet with a cotton swab lightly dampened with rubbing alcohol.
9/27/2010 9:02:09 PM • Canon EOS 450D... • Answered on Sep 27, 2010
tip
Where to find the manual (pdf) for Canon Eos 450 digital camera
Sometimes , it is convenient to have a soft copy of your user manual.You may also require it as you lost your original printed manual. This tip will guide you to your digital manual and explain how to download it.
Printed manuals are normally available at a cost from the product manufacturer. Please see the link below to contact the manufacturer and find out how to replace your printed manual.
To download a soft copy of your manual , please click HERE to go to the retrevo page for your manual. This is a excellent site that maintains a manual and product database of thousands of products available free to download in PDF format.
Please note that you will need pdf viewer software to be able to view the downloaded manual.I can recommend Adobe reader which is available for free download at the following location :
CLICK HERE to go to Adobe Reader download site.
To download you manual from retrevo , follow the link above. You will betaken to the product page. The following images are used as an example.
When your on this page , you can select to see reviews , prices , specs , an overview of the product and of coarse , the manual. You can just hit the big red manual button to proceed.
Now simply type in the capcha code and hit the red “download now” button to begin your manual download.
To go to the manufacturer's contact page , please click on the relevant link below :
Kodak
Sony
Panasonic
Samsung
Fijitsu
Canon USA
Canon Global
Nikon
Phillips
Please rate this tip if you found it useful.
Kind Regards
StephanSA
I just bought a Canon 450D and followed the setup
Sounds like you got yourself a defective CCD sensor inside the camera because you should have got output on the file and on the LCD.
Read the advisory from canon below.
http://www.dpreview.com/news/0510/05100602canon_ccdproblem.asp
You might want to also have a camera shop confirm it for ya. But other then that I cannot think of any other problem that would cause this.
Thanks for your Visit at fixya.com please do click the accept button for my efforts. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
7/6/2010 4:09:33 AM • Canon EOS 450D... • Answered on Jul 06, 2010
Canot open folder
When you removed the card from the camera, was the camera still turned on? When you removed the card from the computer, did you use the "safely remove hardware" function? You may be able to retrieve your pics by taking the card to a Walmart store that has a Kodak picture kiosk machine. It can usually read anything and you can print your pics or even make a cd of them.
4/8/2010 5:03:37 PM • Canon EOS 450D... • Answered on Apr 08, 2010
Deleted photos
When items are deleted (or card formatted) on the media card, it doesn't really wipe the card, it just removes the indexes, thereby making the space available for future use.
All is not lost UNTIL you overwrite the card with new data.
If the card is freshly deleted.... meaning that no new data write activity has occurred since the deletion, then you can usually recover the pictures by using commercial products such as "Undelete".
These work by recreating the indexes, and are usually very effective if the card has not been subsequently used / overwritten.
Costs and results vary - but if you look up "undelete software" on google, you will be offered an array of possibilities - from freeware (no cost) through to around $50.
First thing to do is to stop using that card until your recovery has been performed.
Photo shops (camera stores, or processors) see this kind of error most days, and will be able to sort you out, if it all seems too daunting.
Hope this helps
3/8/2010 10:44:54 PM • Canon EOS 450D... • Answered on Mar 08, 2010
How do I use a canon af lense on a canon 450D IS
Are you using sigma for CANON>
12/28/2009 10:44:35 PM • Canon EOS 450D... • Answered on Dec 28, 2009
My camera's AF is not working for almost 2weeks now.
For troubleshoot, check the bwlow link :-
http://www.slrphotographyguide.com/camera/lens/autofocus.shtml
More likely, you would be able to fix the issue.
Any further help, let me know.
Thanks for using "Fixya'.
6/4/2009 5:37:47 AM • Canon EOS 450D... • Answered on Jun 04, 2009
Occasionally I get 'ERROR 5' appear on the display
This is a common canon mechanical error.
Most of there SLRS do this the release inside the pop up flash hangs either due to weak spring or release catch itself. If it hangs for even a split second you get error code.
Try This.
  1. Clean Flash Release & Apply wd-40 with a q-tip to moving parts. DO NOT SPRAY INTO CAMERA. Use oil lightly.
  2. Or Assist flash when it tries to p up by lifting on flash gently. Maybe one day canon will fix this problem.
PS this happens to even Brand new Canons.
3/8/2009 9:09:57 AM • Canon EOS 450D... • Answered on Mar 08, 2009
My Canon EOS Rebel XS film camera shut off while in use.
How old is the battery? They will only take a certain number of charge and discharge cycles. When worn out, they will charge, but fail very quickly and always in the middle of use. https://www.walmart.ca/en/ip/2x-Pack-Canon-EOS-Rebel-XS-Battery-Charger-Replacement-for-Canon-LP-E5-Digital-Camera-Battery-and-Charger-1200mAh-7-4V-Lithium-Ion/PRD1R0BZPXKL7K5 https://www.google.com/search?q=canon+eos+rebel+xs+battery ..
4/15/2022 6:31:52 PM • Canon Eos... • Answered on Apr 15, 2022
2answers
7d - problem with shots remaining
Maximum for counter is 999. Counter is showing 999 because you have space available for more than 999 shots. If you've got a very large memory card it may tke quite some time to get below 999.
1/13/2018 7:54:04 PM • Canon Eos... • Answered on Jan 13, 2018
Canon EOS 450D Digital Camera with 18-55 Lens Logo
20 questions posted
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
Eos Canon
  • Eos Canon
Most Popular Question
canot open folder
  • Cameras
