20 Most Recent Acer Aspire One AOA110-1588 Notebook Questions & Answers
Your dvd drive has to be capable of reading blu-ray discs. You'll know cause it will have the blu-ray logo on the front of the drive.You will also need a blu-ray software player as well.Here is a link to a forum that I found thru google that compares 4 different blu-ray software players:http://forum.blu-ray.com/showthread.php?t=72239This should help you figure out what software you want to use.
Acer Aspire One... | Answered on Jul 04, 2018
Your hard disk is problem, there is two possible things that make you get that message. First your hard disk is full and there is a problem that windows cannot find specific file, that file maybe damaged or erased or moved to other location. Second your hard disk is about to die :). When and if your successfully finish repairing itself, try to download form the Internet program : " Hard disk sentinel", that program is free of charge. When you finish downloading install it and run. The program will show you in what kind of shape is your drive or drive's if you have more than one. In the filed on top find configuration and than preferences open and click on the " Load at windows startup", uncheck it. When program shows the shape of your hard drive or drives it will also show you estimated time when is predicted it will die. If you have BAD Sectors and program shows you a lot of red fields its time to backup your file and replace that drive.
Acer Aspire One... | Answered on Oct 13, 2017
Skype latest version is not compatible with vista...u need to download the previous version skype 3.0 or 3.5 .....dat will work with vista fine..
Acer Aspire One... | Answered on Apr 11, 2015
get the drive from acer with AOA 110 model
Acer Aspire One... | Answered on Dec 10, 2013
There are couple of troubleshootig steps which needs to be performed inorder to help get a web page load faster.
Go to Tools/options/ and delete the history, cached pages, cookies, password etc. Might want to ignore favourites.
Also type temp in run command line and then delete the files from the folder. This helps to increase the processing speed as well as the browsing speed of the accer.
This works with IE 6/7/8 though.
Thanks
Acer Aspire One... | Answered on May 10, 2013
Which operating system ?
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled. Make sure your antivirus program is not blocking the internet connection. If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc You only need to check the BIOS if you cant install the driver Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"ima Click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all of your internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138
Acer Aspire One... | Answered on Mar 14, 2013
Remove the battery and see if it will boot from just the power cord.
If not, reseat the ram and see if that helps. Otherwise, it might be a bad power supply.
Acer Aspire One... | Answered on Nov 10, 2012
Hi friend,
You can clear the user name and password option from your laptop..you need to open control panel
then
click on user name and password
then
use the change password option
then
dont enter any password..
ok
then restart
system will not ask you any password....
With regards
If you are using the supplied Acer program to setup your wireless, I would suggest removing the program. In most cases, removing their software does not remove the drivers, and thus, Windows Zero Configuration will take over the wireless.
WZC, in my opinion, works very reliably and has solved this type of issue in the past, although it is not the only reason for disconnects. For instance; a weak signal and a lot of interference from neighboring networks can cause your wireless to become unstable.
If this doesn't fix your connection issue, you may have an issue with the wireless card itself.
Acer Aspire One... | Answered on Nov 01, 2012
There are two way's you can restore your laptop,
When you power on your laptop the acer splash screen pop's up, at that time press the -Alt- key and F10 key at the same time,
at the eRecovery Management menu it should ask you how you want to restore, click on the restore option, or
From the window's desktop click on start, then all program's, then acer Empowering Technology, click on Acer eRecovery Management, create a password, click on restore, then click on restore system to factroy default.
Acer Aspire One... | Answered on Oct 09, 2012
This article may help you....or these.
If you can turn off the auto restart to get a stop error code from the blue screen, that will help you to diagnose this error. See 'disabling restart..." here. Then reboot and note the exact error code reported. Write back with that info and we'll help you to sort it out.
You can look up codes here.
Also helpful links for blue screens here, here, & here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Acer Aspire One... | Answered on Jun 01, 2012
Have had similar problems with two Gateways that are actually Acer--both two feet away on either side of each other: one or the other will lose connection--so not the units---if move the one not connecting closer (it is 50 feet with 3 walls between it and router) it will then pick up the wireless and work fine--I answer about 300 questions here each week so end up to avoid this in the mud/laundry room where I can depend on the signal and also have a smoke if I want.
May want to as a test move it closer to the router and see if same issue or not.
Acer Aspire One... | Answered on Apr 22, 2012
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Acer Aspire One... | Answered on Mar 19, 2012
Read this link if you like
http://www.techimo.com/forum/applications-operating-systems/136282-fix-ntldr-missing-xp-works-2000-well.html
Goodluck
Acer Aspire One... | Answered on Oct 31, 2011
Hi gbirdmsn211..
Make sure you have "Flash Player" download on your computer, it is availble from Adobe for free...that might be the missing one you need.
Please take time to rate me
Acer Aspire One... | Answered on Aug 31, 2011
Try booting in safe mode (press F5 after Acer logo is gone)
Then do a system restore.
That might fix the problem.
Acer Aspire One... | Answered on Aug 16, 2011
You can speed up your netbook by:
-- cleaning system junk
-- optimizing computer services
-- optimizing internet
-- repairing registry
-- defraging registry
-- clearing browsers junk
do these things with some secure tool such as Intel Software Partner Reginout.
Thanks
Acer Aspire One... | Answered on Jun 20, 2011
BIOS passwords can be reset in two ways,
1. using software 2. using hardware.
Here are two software's to reset or retrieve BIOS passwords.
!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore.
Cmospwd - Cmos password recovery tools
Hope this will for you :)
Thanks
Acer Aspire One... | Answered on May 06, 2011
Hi John,
To start off check your disc space. XP has this paging file that builds up over time and use. It also depends on the applications that you install and if it is running in the background. These are the applications that is activated every time you start up your machine.
You may also check on the amount of RAM you have in your system. Lets say you have 2 gb installed, around 500 mb or more is already assigned to your hardware and operating system. So that means you have 1.5 gb of RAM left for other applications and processes. So lets say you watch a few videos, and play a lot of flash games, your RAM will slowly be spent up. Once your RAM runs out, your hard disc space will act as your system RAM as virtual memory. So if your going to be using a lot of applications that takes a lot of resources for your RAM, it will be real slow in the long run. You do have the option to close a few unwanted applications, or do a system restart to refresh your system.
So now you'll be wondering, if you need to do that all the time now? Not exactly, remember the applications automatically start up once you on your machine? You can customize that to your liking now. There's two ways. First, you need to customize your installation wherein you select the option not to run the application automatically on Start. The second one is to remove the application from start up. One was is by removing it in Msconfig in windows. To launch it, just click on Start, then select Run, then Type Msconfig. You will then see a screen where you can see the start up items. Then just select the Start up applications that you don't want to open anymore on Start and untick it...and...Thats a lot of start eh....then you'll be doing a restart. For kicks, try to untick all and see how fast your system loads up.
Are you getting the picture now? Lesser applications on start up, more RAM for your system. SO just open up what you need and close what you don't.
And then there's the browser helpers, trial applications, and other stuff thats just there, installed in your computer. Just remove all that is unneeded! Imagine a room full of stuff you don't really need. Its messy. That also happens to your machine.
Anti-Malware and Windows Update. This goes hand in hand, better invest in an AntiVirus or Anti Malware subscription to protect you from the typical trojan or malware. Then do regular windows updates, to patch your system. Scan often and update often.
Lastly, delete unwanted files, it's just adding to your disc space. Do disc clean up and Defragment your discs every 3 weeks if possible. It is also best to shutdown your machine after use so once you start it up again, its fresh.
Electro35
Acer Aspire One... | Answered on Apr 21, 2011
Acer Aspire One AOA110-1588 Notebook Logo
149 questions posted
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
acer aspire loses its signal randomly
  • Computers & Internet
