20 Most Recent
Proscan Used Original 40LC45S57 Remote Control Questions & Answers
My tv is blinking a blue light when I try to turn it on along with a popping sound.
It sounds like there may be an issue with the power supply or internal components of your Proscan PLDED5030A-RK TV. The blinking blue light and popping sound could indicate a malfunction that is preventing the TV from turning on properly.
Here are a few steps you can try to troubleshoot the issue:
1. Unplug the TV from the power outlet and leave it unplugged for at least 10-15 minutes. This can help reset the internal components of the TV.
2. Check the power cord and connections to ensure they are secure and not damaged. If there are any visible signs of damage, such as frayed wires, replace the power cord.
3. Try plugging the TV into a different power outlet to see if the issue persists. This can help determine if the problem is with the power source.
4. If the issue continues, it may be necessary to contact a professional technician or the manufacturer for further assistance. They can diagnose the problem and recommend the appropriate repairs.
It's important to exercise caution when dealing with electronic devices, especially when there are signs of malfunction such as unusual sounds or lights. If you are unsure or uncomfortable with troubleshooting the issue yourself, it's best to seek help from a qualified professional.
3/22/2024 11:46:39 AM •
Proscan...
Answered
on Mar 22, 2024
Does a proscan model PLED5544U have a reset button
The Proscan PLED5544U is a 55-inch LED TV. While it doesn't have a physical reset button, there are a few ways you can reset it:
- Unplug the TV: Unplugging the TV from the power outlet for a few minutes can help reset it. This allows any residual power to dissipate and can clear any minor software glitches.
- Use the remote control: Press and hold the power button on the remote control for at least 10 seconds. This can sometimes reset the TV.
- Use the menu: If you can access the TV's menu, you can try resetting it through the settings. Go to the "Settings" menu, then "System" or "General" settings. Look for an option to reset the TV to its factory settings.
If none of these steps work or if you're experiencing other issues with your TV, it may be best to contact the manufacturer or a qualified technician for assistance.
2/27/2023 6:07:50 PM •
Proscan...
Answered
on Feb 27, 2023
Proscan Tv/dvd magnovox universal remote codes
Here are some Magnavox universal remote codes you can try to use with your Proscan TV/DVD combo:
- 11963
- 11603
- 12746
- 12260
- 10587
- 12070
- 11990
- 10178
- 10030
To program the Magnavox universal remote to control your Proscan TV/DVD combo, follow these steps:
- Turn on your TV/DVD combo and point the Magnavox universal remote at it.
- Press and hold the "Code Search" button on the remote until the LED light on the remote turns on and stays on.
- Press the "TV" button on the remote to program the remote to control your TV.
- Enter one of the codes listed above using the number buttons on the remote. The LED light on the remote should turn off if the code is accepted.
- Test the remote by pressing the "Power" button to turn on the TV/DVD combo. If it works, try other buttons on the remote to control your TV/DVD combo.
- If the first code you entered doesn't work, repeat steps 2 to 5 with another code until you find the correct one.
If you are still having trouble programming your remote, consult the user manual or contact the manufacturer for assistance.
2/26/2023 4:02:08 AM •
Proscan...
Answered
on Feb 26, 2023
I have a proscan elite tablet and dvd combo. Some how I locked it. Help!
If your Proscan tablet and DVD combo is locked, you can try the following steps to unlock it:
- Restart the device: This is the simplest and quickest solution. Simply restart the device by holding down the power button until it shuts off, then turn it back on.
- Check the lock button: Some devices have a lock button that can be used to lock and unlock the device. If your Proscan tablet has a lock button, check to see if it's in the locked position and adjust it if necessary.
- Reset the device to factory settings: If restarting the device and checking the lock button don't work, you can try resetting the device to its factory settings. This will erase all data and settings on the device and restore it to its original state. To reset the device, you may need to access the settings menu and look for an option to reset the device or perform a factory reset.
- Contact the manufacturer: If you're unable to unlock the device using the steps above, you may need to contact the manufacturer for further assistance. They should be able to provide you with more specific instructions on how to unlock your device, or if necessary, repair or replace it.
I hope this helps! Let me know if you need anything else.
2/12/2023 6:26:49 PM •
Proscan...
Answered
on Feb 12, 2023
Proscan 3373A. Hard reset for 3373a Proscan
The model doesn't exist. All question need
'make model (what it is)', first 3 words and in that order.
"channel button". is it a television? Reset would be in Settings / General. You have the Remote? All sets need a Remote.
https://www.google.com/search?q=proscan+3373a
They make a lot of stuff!
Proscan Video - TVs, tablets, DVDs, and camerashttps://www.proscanvideo.comProscan manufactures and distributes quality electronics & appliances such as Televisions, Tablets, DVD systems, portable and home stereos, and cameras.Contact Us · Television · About Us · Manuals & Downloads
Proscan Tablet reset, Standard Android Hard Reset.
1/29/2023 6:26:15 PM •
Proscan...
Answered
on Jan 29, 2023
How to fit a sound bar to a proscan tv
1) Go the Sound Tab on the remote's Proscan menu
2) Set the system's "Digital Audio Output" to PCM (pulse code modulation)
3) Connect a coaxial cable from the Coaxial "jack" on the back of the TV to the Digital Input "jack" on the back of the sound bar.
It should work now!
8/7/2022 6:42:02 AM •
Proscan...
Answered
on Aug 07, 2022
