20 Most Recent
Dell Latitude E5500 Notebook Questions & Answers
How to start blutooth sharing
First you need to have a Bluetooth adapter either external or built in, then you need to have Bluetooth software one of them is blue soil once downloaded and installed then you can pair both devices and check the option of allow sharing.
Can i use a cam on dell latitude e5500?
Click start control panel view devices and printers you should see your webcam from there
if you are have trouble with your webcam
Click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark?
right click to reinstall drivers or update driver xp
Click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: webcam name webcam driver you might have to try a few times to get it right
software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
It might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions
this will automatically search for and find the correct driver
you will have to update every driver individually once you update you might be asked whether you
want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated
Some webcams and programs require additional software, although that should be installed with the webcam if things are right.
But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date.
But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing.
Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10).
http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer
hope this helps
My laptop is a dell latitude e5500 is showing a error code 0146
Run Check disk to repair problems related to bad sectors, lost clusters, cross-linked files, and directory errors.1. Click Start, and then type cmd in the Start Search box.2. Right-click cmd in the Programs list, and then click Run as administrator. If you are prompted for an administrator password or confirmation, type your password or click Continue.3. At a command prompt, type the following command, and then press ENTERchkdsk /f /r X:( drive letter)4. Press Y when you are prompted to check the disk the next time that the system restarts.5. Close all applications, and then restart the computer.For an instant fix of this error, use a system utility tool like Reginout.
Unable to run .exe files
open recycle bin and paste the following link.http://www.winhelponline.com/articles/105/1/File-association-fixes-for-Windows-Vista.htmlyou will got a table on this page, and in that you have to select exeAs you click on exe, it will ask you for open, so open it.In that there is 1 file, run thatand it will fix the issue.if still not try to create a new user account from control userpasswords2 and restart the computer.after that try to work in new user account.
How to set up microphone
In Skype go to your settings, then look for the audio. It is usually set to something other than your factory mic... change it to the mic for your model computer.
I lose my password
sorry i cant remember what it was either
if you expect to get help on problem , then stop being lazy and type a LOT more info on what you are doing, is it a bios password? a windows password? a hard disk password? a power on password?
I am using Dell Latitude E5500 at home, I am
Try to uninstall and reinstall your Local Area Network driver by going to the device manager from the control panel. expand the network adapter and right-click your LAN then select uninstall. Restart your computer and windows will automatically reinstall your LAN driver.
How to listen to an IPOD with laptop
according to you it seems you want to listen the songs which is in the IPOD if it is this then download i tune plug you IPOD and open it in the itune and enjoy
