20 Most Recent Lexmark E260dn Laser Printer Questions & Answers
1.Turn the printer off.2.Open Front cover.3.Press and hold X button.4.Relese X when the ! LED is illuminated. Note:Be patient as the LEDs will light up in multiple patterns before finaly stopping at !.5.Close front cover. Note:Observe that green button and 3 other LED will be illuminated at the same time.This is Home position.6.Slowly press X button until the 3 first LED are illuminated (paper,toner,light)Note:normaly this will require you to press the X button 11 to 13 times depending on the options and features installed.7. Press and hold green button until all LED flasch or strobe from left to right then relese the button.wait until this process stops with the same pattern as step 6.8.Press and hold X until the light pappern return to the pattern of four LED in theHome position.9.Turn the printer OFF.10.Turn the printer On.Note:if on a DHCP network, wait 30 seconds to see if the DHCP server/router sends out an IP adress to the device.11.Press green button to print a setting pages and observe that all the TCP/IP settings have been reset.12.Reconfigure the device using DHCP.Auto IP(zero configuration) or the IP Setup Utility.
This is my solution to the problem.//Oaklunde
Lexmark E260dn... | Answered on Apr 01, 2019
find on the users manual.
Lexmark E260dn... | Answered on Oct 01, 2018
Blinking status light means the printer is busy. If it's not doing anything else, disconnect the printer from the computer. Restart the printer and then print a menu settings page. Clear the print queue on your computer before re-attaching the printer. Thanks.
Lexmark E260dn... | Answered on Sep 12, 2018
I typically install drivers for the newer OS first and then the older.
Try downloading the Win7 drivers and install them on the Win7 computer. Then install the additional XP drivers.
Lexmark E260dn... | Answered on Apr 29, 2017
http://support.lexmark.com/index?page=content&locale=en&productCode=&segment=SUPPORT&clearQuestion=Y&userlocale=EN_US&id=HO3026
That is a general printer error
Check for jams or blocks. you might have to delete the driver and clean the registry I use revo uninstall. then install the latest firmware
Sir Dana
Lexmark E260dn... | Answered on Apr 26, 2017
FIXYA can not assist you either . MOST printers now will not work with non OEm cartridges .
Lexmark E260dn... | Answered on Mar 10, 2017
its the toner light or photocondutor light?
Open door and push stop for 15/30 sec.
Lexmark E260dn... | Answered on Feb 14, 2017
The light bulb light #5 indicates that the printer is ready to print. Therefore the problem lies with the computer side. Typically the problem is that the printer port in Windows does not match the printer port the printer is currently assigned to. If you have the printer connected via ethernet, then your router may have assigned an ip address that is different than when the printer was first set up. You have to go into the printer properties in the control panel, and make sure the port address matches the printer. Once the port is correctly configured, the printer will immediatley start to print.
Lexmark E260dn... | Answered on Nov 05, 2016
Did you remember to specify envelopes in the printer properties dialog box? Click the button that says Preferences. Then click the Paper/Finishing tab. Under Paper Size, select your envelope size.
The printer will not feed the envelopes correctly without specifying this. The Lexmark printers adjust feed tension based on paper size settings.
Restoring the factory default settings
Do one of the following:
• If your printer is on a network, access the Embedded Web Server:
1 Type the printer IP address into the address field of your Web browser.
Note: If you do not know the IP address of the printer, print a network setup page and locate the IP address in the TCP/IP section.
2 From the Settings screen, click General Settings.
3 Under Factory Defaults, select Restore Now, and then click Submit.
• If your printer is connected to a computer by a USB or parallel cable, use the Local Printer Settings Utility for Windows or Printer Settings for Macintosh.
1 Open the utility.
2 Do one of the following:
– From the Local Printer Settings Utility menu bar, click Actions Restore Factory Defaults.
– From Printer Settings, click Factory Defaults.
Warning—Potential Damage: Restore Factory Defaults returns all printer settings to the factory default settings except Network/Port menu settings. All downloads stored in RAM are deleted. Downloads stored in flash memory or on a printer hard disk are not affected.
Or please download the user guide from this link and follow the instructions
http://static.tigerdirect.ca/pdf/Lexmark-E260D-Series-Mono-Laser-Printer-Manual.pdf
Hope this will help you
thanks
Lexmark E260dn... | Answered on Apr 07, 2015
1.Turn the printer off.2.Open Front cover.3.Press and hold X button.4.Relese X when the ! LED is illuminated. Note:Be patient as the LEDs will light up in multiple patterns before finaly stopping at !.5.Close front cover. Note:Observe that green button and 3 other LED will be illuminated at the same time.This is Home position.6.Slowly press X button until the 3 first LED are illuminated (paper,toner,light)Note:normaly this will require you to press the X button 11 to 13 times depending on the options and features installed.7. Press and hold green button until all LED flasch or strobe from left to right then relese the button.wait until this process stops with the same pattern as step 6.8.Press and hold X until the light pappern return to the pattern of four LED in the Home position.9.Turn the printer OFF.10.Turn the printer On.Note:if on a DHCP network, wait 30 seconds to see if the DHCP server/router sends out an IP adress to the device.11.Press green button to print a setting pages and observe that all the TCP/IP settings have been reset.12.Reconfigure the device using DHCP.Auto IP(zero configuration) or the IP Setup Utility.
Lexmark E260dn... | Answered on Mar 23, 2015
You may be having a driver problem.
Uninstall the product and install again - using the driver that came with the product (on CD or Internet) and not the generic windows driver. This is especially important if you are using it on a network or as a network printer.
Also look at the printer preferences: How is it sent to the printer? Try spool then print.
Lexmark E260dn... | Answered on Sep 09, 2014
Lexmark E260dn Laser Printer Logo
284 questions posted
Top Lexmark Office Equipment & Supplies Experts
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
E Lexmark
  • E Lexmark
Most Popular Question
lexmark e260dn load paper light
  • Office Equipment & Supplies
