20 Most Recent Fisher and Paykel DE27CW1 Electric Dryer Questions & Answers
Fisher Paykel Dryer Fault Code 22 Info
That is a fault for the "Door Actuator Open Circuit". You may have not had the door closed completely and when you opened the door to check it out, you closed it completely. Another possibility is the sensor module is going bad.
6/14/2016 7:35:24 AM • Fisher and... • Answered on Jun 14, 2016
0answers
Heating element
Be the first to answer 10/24/2013 5:01:18 AM • Fisher and... • Posted on Oct 24, 2013Be the first to answer
My DE62T27D Fisher and Paykel electric dryer stopped heating .What should I check?
more likely its the heating element
3/21/2012 12:40:40 AM • Fisher and... • Answered on Mar 21, 2012
F*P de27cw1 top load dryer.....is
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
9/19/2011 1:44:42 PM • Fisher and... • Answered on Sep 19, 2011
I have a f and p DE27CW1 that is not drying right.
Hello & Welcome to FixYa
If you have already cleaned the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair. It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing.Please get back to me if you have any other questions.
Kevin
8/14/2011 11:29:26 PM • Fisher and... • Answered on Aug 14, 2011
Te dryer has started making a roaring or vibrating
check your blower wheel
7/20/2011 6:39:46 PM • Fisher and... • Answered on Jul 20, 2011
Have fisher paykel drier model DE27CW1 -
http://www.technostation.com/user-guide-owners-manual/Fisher+%26+Paykel/Fisher+%26+Paykel+DE27CW1+Dryer
Ok, well unfortunately, this symptom doesn't tell us much :( Other than, the dryer is getting power? Obviously, it will NOT perform any functions. Now when something like this happens, it can, unfortunately,be one of many, many, many things. From, bad sensors, to spiked electronics. There is no real way to tell, unless specific symptoms, or Error codes are displayed. Accordingly, one will have to troubleshoot the entire system to find out exactly what is wrong, often the place to start is with the main Brain, and Sensors, however to do this one either must be experienced or obtain a service manual, as all units differ in operation and circuitry.
So, it is my professional advice to you, that you contact an F&P repair center, and ask that they call and give you a "Quote" as to the cost and type of repair required. This way at least one can get an idea of costings before making a decision as to what to do, repair or replace.
Many of my customers these days often prefer to put any larger amounts of money, that would be spent on a repair towards the purchase of a NEW unit, with a full warranty, now i also say this as I am aware of statistics that show to overall, a unit that has been repaired after a major failure, for whatever reason, will usually fail again within the next 12 - 18 months..
4/1/2011 4:09:18 AM • Fisher and... • Answered on Apr 01, 2011
Will not heat up and
bad heating element ... you can try www.reliableparts.com or .ca
3/23/2011 10:09:34 PM • Fisher and... • Answered on Mar 23, 2011
Dryer is not getting hot
These dryers have an auto spark ingnitor just like a gas stove. They do go bad and need replacement. Upon turning on your dryer, you should hear the ignitor click at least once to ignite the burner. If not I would check the continuity to that ignitor first
1/22/2010 12:48:14 AM • Fisher and... • Answered on Jan 22, 2010
2answers
My fisher and paykel dryer timer for 90 minutes only lasts for 20 minutes and then its completed how do I fix this.Thanks
You may have bad timer or bad motor windings ? does it shut off after 20 minutes and can u start it back up right away? if not start fast then bad motor windings. try using a diff dry setting and see if it does same thing you may need to check the cycling thermostat too test 4 bad motorwindings4-undefined-undefined-0_0.jpg fuses dryercyclingfuse-undefined-undefined-2_2.jpg fuses highlimit thermostatlt-undefined-undefined-5_1.jpg knob-on-dryer-broken-undefined-undefined-9.jpg
12/13/2021 2:59:46 AM • Fisher and... • Answered on Dec 13, 2021
Dryer shuts off during cycle. Usually can be
cycling thermosta
8/21/2021 9:02:52 AM • Fisher and... • Answered on Aug 21, 2021
F & p de35 clothes dryer gets hot say 20 mins running then cuts out ,nothing cools for say 5 to 10mins away it goes ,i have changed the motor was told the thermo switch in was faulty betta after still
Dryer runs then shuts down wont start up for an hour: or 20 minutes Bad motor windings also check for a b ad cycling thermostat test 4 bad motorwindings4-undefined-undefined-0.jpg blower insides07-undefined-undefined-2.jpg fuses highlimit thermostatlt-undefined-undefined-4_0.jpg backofdryer-undefined-undefined-7_0.jpg
8/21/2021 9:02:23 AM • Fisher and... • Answered on Aug 21, 2021
My F&P gas dryer runs but I can hear the combustion fluttering during drying process and of course it’s taking longer than normal. It does NOT shut off like others above. Lint has been thoroughly cleaned from all areas.
ELECTRIC Dryer no heat or little heat, or shuts down to fast: Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it) Next check the heating element itself with a meter for continuity it should show OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating. The heating elements are located inside the heater ducts. If you think a heating element is faulty, test it with avolt-ohm-multimeter (VOM)set to the RX1 scale at 20K ohms. Disconnect the leads from the power terminals and clip one probe of the VOM to each terminal. The meter should read about 12. (1200) ohms. If the reading is higher ohms, the heater is faulty and should be replaced. Replace a faulty heater with a new one of the same type and electrical rating. A heater connected to a 115-volt line usually has an 8.4-ohm resistance; a heater connected to a 220-volt line usually has 11 ohms resistance. Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220, OR you may have a broken centrifugal switch in the motor because this switch activates the motor and the heater as well. supposed to be if the motor does not run, the heater should not heat in order not to create a fire but if the motor is not running, and the heater is still heating, then there could be a problem with the motor centrifugal switch that is connected to this interlock switch that should trigger the heater. Check the thermal cut off, the cycling and the hi limit thermostats. For continuity or OHMS. If no ohms or resistance they need replacement. In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum this is why in some cases the dryer will operate at lower cycles like gentle or low heat but not at higher settings?) Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet. Test with a meter at room temperature and it should show continuity. A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats. Read more : https://www.youtube.com/watch?v=wVTBrGMql7g http://www.ehow.com/info_12203962_check-dryer-thermistor. GOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE https://www.youtube.com/watch?v=MMP7BW1lLs4 gas safety valve gas breakdown-undefined-undefined-0.jpg gasdryer guts-undefined-undefined-2.gif gas safetyvalvelt-undefined-undefined-4.jpg
8/21/2021 9:02:16 AM • Fisher and... • Answered on Aug 21, 2021
F/p dryer start button starts flashing when pushed once starts on second push and turns off after about 1min
The timer: Located in the control console of the dryer the timer consists of a small motor connected to a series of gears that rotate cams, which turn electric contacts off and on inside the timer. The timer contacts control the dryer motor as well as the heat circuit and the timer motor itself. A defective timer motor or a defect in the timer's electrical contacts can cause the timer motor to fail and the timer will need to be replaced. The contacts can be checked for continuity with a multi-meter. This test should only be made when the dryer is unplugged. Another test u can do is observe by eyesight and see does the timer advance or is it stuck on one cycle? 1. On gas and electric dryers that have an "Auto Dry" cycle, the cycling thermostat is often used to advance the timer as well regulate the drum temperature. Essentially, thermostat will alternately turn on the heat source or the timer motor when the temperature has been satisfied. To check this thermostat, you will have to check for power to the timer motor with a multi-meter, during a cycle. This is a live voltage test and caution should be used. 2. Some dryers will use a cool down thermostat to tumble the clothes without heat, at the end of the dry cycle. Power is routed through this thermostat to the drive motor to keep it running until the drum temperature has dropped to a specific temperature. If this thermostat fails it can cause the drum to turn indefinitely or until the door is opened. You can check the thermostat for continuity with a multi-meter. This test should only be made with the power removed from the dryer. Lastly check the moister sensor for OHMS according to ur schematic as it must show a certain amount of ohms as per ur unit. When unit has been on short while Electric dryer no start does nothing Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING. NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position. If you hear a humming/clicking sound from motor area you more than likely have a bad motor. Try this test out to see if u have weak windings or relay/capacitor on motor. Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings Another thing to check is the belt safety switch. With a multi meter. Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released. Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad. https://www.youtube.com/watch?v=MhVUEhngZMg beltswitcht 5-undefined-undefined-0_0.jpg beltswitch-dryer-lint-filter-in-door7-undefined-undefined-1.jpg beltswitch-dryer-lint-filter-in-door7-undefined-undefined-2.jpg knob-on-dryer-broken-undefined-undefined-3.jpg knob-on-dryer-broken-undefined-undefined-5.jpg knob-on-dryer-broken-undefined-undefined-4.jpg teststartswitchr1-undefined-undefined-6.jpg teststartswitchr1-undefined-undefined-7.jpg teststartswitchr1-undefined-undefined-8.jpg teststartswitchr1-undefined-undefined-9.jpg timer motor wires-undefined-undefined-10.jpg timer motor wires-undefined-undefined-11.jpg timer motor wires-undefined-undefined-12.jpg timer motor wires-undefined-undefined-13.jpg timer motor wires-undefined-undefined-14.jpg
8/21/2021 9:02:12 AM • Fisher and... • Answered on Aug 21, 2021
Fisher and Paykel Dryer making noises after moving it
DRYER MAKES NOISES. A loose or worn BELT can make funny noises Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt. The glides on drum worn and making metal to metal contact. The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out. CHECK FOR LOOSE BELLOES inside the drum Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing. The blower: Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel. The bearings: The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process. The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it. The drum rollers or castors: It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers. Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them. GOD IS GOOD !!!! drum-glidesr-undefined-undefined-0.jpg drum support dryer-undefined-undefined-2.jpg roller bad dryer rroller-undefined-undefined-5.jpg roller good dryer roller-undefined-undefined-9.jpg
8/17/2021 6:48:29 AM • Fisher and... • Answered on Aug 17, 2021
Dryer not heating up, lint filter keeps beeping & seems to be water pooling near condenser. We emptied water tank, cleaned lint filter & condenser filter but it is still doing the same thing
ELECTRICDryer no heat or little heat, or shuts down to fast: Checkyour venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it) Next check the heating element itself with a meter for continuityit should showOHMS CLOSED CIRCUIT. If not its defectiveor has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating. The heating elements are located inside the heater ducts. If you think a heating element is faulty, test it with avolt-ohm-multimeter(VOM)set to the RX1 scaleat 20K ohms. Disconnect the leads from the power terminals and clip one probe of the VOM to each terminal. The meter should read about 12. (1200)ohms.If the reading is higherohms, the heater is faulty and should be replaced. Replace a faulty heater with a new one of the same type and electrical rating. A heater connected to a 115-volt line usually has an 8.4-ohm resistance; a heater connected to a 220-volt line usually has 11 ohms resistance. Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,OR?you may have a broken centrifugal switch in the motor because this switch activates the motor and the heater as well. supposedto be if the motor does not run, the heater should not heat in order not to createafire but ifthe motor is not running,andthe heater is still heating, then there could be a problem with the motor centrifugal switch that is connected to this interlock switch that should trigger the heater. Check the thermal cut off, the cycling and the hi limit thermostats. For continuity or OHMS. If no ohms or resistance they need replacement. In somedryer'sthecontrol panel relies on athermistorrather than aCYCLING thermostatto regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when thethermistorindicates that more heat is needed to keep the air temperature constant inside the drumthis is why in some cases the dryer will operate at lower cycles like gentle or low heat but not at higher settings?) Lastly check your moister sensor.( located inside the dryer door usually) Especially if machine seems to shutdown early and clothesare still wet. Test with a meterat room temperatureand it should show continuity. A failed moisture sensor will affect the dryer run timein the automatic moisture sensing cyclebut it will not affect the heatingof the dryer or the timed cycle.Which are reflected by the thermostats. Read more : https://www.youtube.com/watch?v=wVTBrGMql7g http://www.ehow.com/info_12203962_check-dryer-thermistor. GOD IS So GOOD !!!!AND THAT'S WHY MY ADVICE IS FREE heating-element-bad coil-with-housing-240v-undefined-undefined-0.jpg drum glides dryer door-undefined-undefined-2.jpg vent tube bad -undefined-undefined-5_1.jpg venting in cabinet clogged-undefined-undefined-9_0.jpg test dryer element-undefined-undefined-14_0.jpg
3/28/2020 8:51:02 PM • Fisher and... • Answered on Mar 28, 2020
Fisher and Paykel DE27CW1 Electric Dryer Logo
24 questions posted
Top Fisher and Paykel Dryers Experts
Virgil Watts
john h
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
View Most Popular
  • Fisher and Paykel Dryers
Most Popular Question
f p de27cw1 not drying right
  • Dryers
