Hello friend, thank you for allowing me the opportunity to assist you!
The screws that are used to install the dryer cord to your Frigidaire dryer terminal are stainless 1/4 inch screws. I hope this is helpful. -Matt
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
46 questions posted
640 Questions
525 Questions
217 Questions
197 Questions
121 Questions
