20 Most Recent Kenmore 500 6953 Dryer Questions & Answers
Dryer just turned itself off
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
9/5/2011 7:20:21 PM • Kenmore 500 6953... • Answered on Sep 05, 2011
I have a Kenmore 500
the door switch is broke.when you push on the paddle of the door switch the lite should go out,if you don't see the paddle it most likely broke off,you need to send the full model number next time,it will start with 110.or similar.the door switch is a safety so the machine won't run until the door is closed,if the switch is broke no power will go to start the dryer
5/10/2011 9:14:27 PM • Kenmore 500 6953... • Answered on May 10, 2011
Dryer those not heat up,
could have a bad gas valve/regulator on unit...also i have seen the ignitors be bad and still glow they have to send enough current back to open the valve up.... good luck to you ....
1/5/2011 5:39:47 AM • Kenmore 500 6953... • Answered on Jan 05, 2011
Power to panel buttons but
Could be a blown duct fuse:
old design:
New design:
Manual and more HERE If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1/3/2011 8:12:31 PM • Kenmore 500 6953... • Answered on Jan 03, 2011
SEARS 500 SERIES KENMORE DRYER IS ON WORKING BUT
timer maybe:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
10/30/2010 2:36:36 AM • Kenmore 500 6953... • Answered on Oct 30, 2010
No heat where is the fuse located is there a
check this site out it is the best:
Hope this helped Tim
10/16/2010 1:14:38 PM • Kenmore 500 6953... • Answered on Oct 16, 2010
My basement flooded and now my dryer won't
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The motor got wet and is no good anymore...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
9/13/2010 2:15:58 AM • Kenmore 500 6953... • Answered on Sep 13, 2010
Kenmore 500, blows the breaker everytime i turn it
It could be differnt reasons, check to see if it drains, if not, then something can be in the pump, if not then timer or motor shorting or it can even be transmission siezed.
5/16/2010 1:50:03 AM • Kenmore 500 6953... • Answered on May 16, 2010
My kenmore 500 top loader dryer is leaking from
A small sock can get sucked under agitator and get stuck in the water pump, either that or a seal is bad somewhere.
4/15/2010 3:24:36 AM • Kenmore 500 6953... • Answered on Apr 15, 2010
HOW COME THE DRYER DOES NOT BLOW AIR
too much cloths in dryer, blower fan not working if electric dryer then look at breaker box and check to see if breaker triped
4/9/2010 7:16:00 PM • Kenmore 500 6953... • Answered on Apr 09, 2010
Our Kenmore 500 series dryer is about 3 years old.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
http://www.fixya.com/support/r4312805-dryer_maintenance
heatman101
4/6/2010 3:45:03 AM • Kenmore 500 6953... • Answered on Apr 06, 2010
Reinstalling dry belt with idler
Disassemble it to remove the drum and reassemble it.
1/3/2010 2:11:45 AM • Kenmore 500 6953... • Answered on Jan 03, 2010
Dryer has power but will not start
Assuming this is a full size 240v dryer (you never said what it is) you should have 240 volts across the two angled prongs in your receptacle (L1 and L2). 120v across either ONE angled prong to the "L" shaped prong (neutral).
If it a 120v dryer your voltages are alright.
It sounds like the door switch is open.
1/3/2010 2:10:09 AM • Kenmore 500 6953... • Answered on Jan 03, 2010
How do you change the door switch kenmore 500 series dryer
Two metal clips hold the lid down, if the lint trap is on top there will be two screws under it.  Pop the clips with a long skinny flathead, lift the lid up and the door switch should be on top.
12/19/2009 9:49:24 AM • Kenmore 500 6953... • Answered on Dec 19, 2009
Dryer trouble
if there's water it sounds like you have a vent problem,go outside and see if air is blowing out strong and flapper is opening,dryer needs a clean out and blow out the vent line
11/19/2009 10:11:45 PM • Kenmore 500 6953... • Answered on Nov 19, 2009
I need to know where the time delayed fuses are on
the only fuse on a dryer might be on the electronic control panel there are no time-delay fuses inside the unit,do you have power to the unit? or does it stop heating or quit all together,if it quits heating its probably your hi-limit thermostat on the element case or cycling thermostat
9/26/2009 1:30:24 PM • Kenmore 500 6953... • Answered on Sep 26, 2009
My washer drain pipe is overflowing on my floor
Sounds like your drain pipe is restricted or clogged. Try using a "Pipe Snake" to unclog.
7/26/2009 1:34:00 PM • Kenmore 500 6953... • Answered on Jul 26, 2009
The dryer will not heat up
Firstly, make sure that you have selected a heat setting or that a heat selection has been ascertained, then follow the tips provided below. If you are uncertain about your diagnostic prowess, please contact a qualified technician, as they will have proper training and test equipment. We can help you locate a qualified technician in your area.
For DIY on-line parts and repair help, you can utilize www.repairclinic.com or,
www.homemanagement.services.officelive.com for other helpful links.
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
7/6/2009 3:03:25 PM • Kenmore 500 6953... • Answered on Jul 06, 2009
Kenmore dryer. Tension pulley was off, put it back
Watch the video If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
7/4/2009 2:55:18 AM • Kenmore 500 6953... • Answered on Jul 04, 2009
2answers
Trying to find out how much part #7 on the exploded view of the Kenmore elite electric dryer model 110.2808 is? It is a motor.
110.2808 is an incomplete model number. Motors are typically $140 to $180 USD https://www.easyapplianceparts.ca/PartInfo.aspx?inventory=334304&SourceCode=18 This is is a typical Kenmore model designation and is probably the matching washer to your dryer. Yours is missing 4 numbers. Label in the back, label on the door frame, mentioned on the manual.
Model # 11028081700 Official Kenmore Elite washer
https://www.google.com/search?q=Kenmore+elite+electric+dryer+110.2808 ..
2/23/2024 6:44:28 PM • Kenmore Dryers • Answered on Feb 23, 2024
Kenmore 500 6953 Dryer Logo
20 questions posted
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Dryers
  • Kenmore Dryers
Most Popular Question
change door switch kenmore 500 series
  • Dryers
