20 Most Recent Kenmore Elite HE3 Steam 8674 Dryer Questions & Answers
My kenmore elite he3 dryer does not heat up
Symptom: Dryer turns on, drum spins, but you have no heat.
Any of the following components are more than likely suspect as being bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel. (HINT: placing a block of wood under the front feet of the dryer can make access much easier). If your dryer has no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) - remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
NOTE: One item I failed to mention - Double check the input power for your dryer FIRST. You should have 220VAC at the receptacle and terminal block. The dryer will STILL tumble and the timer will still function with a portion of the input power missing as these circuits only require 110VAC. The heating circuits, however, require 220VAC to function. If one leg of the receptacle voltage is missing the dryer may exhibit "No Heat" like symptoms. This could also be an indication of a burned or failed power cord. Continuity checks performed with the dryer UNPLUGGED should indicate a short between the prong end of the cord and the respective lugs at the terminal block.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
4/15/2023 9:36:24 PM • Kenmore Elite... • Answered on Apr 15, 2023
How do I dry a foam pillow
do not use a drier the heat from the drier will release the rubber smell and make it unusable best just to air dry on a line
8/8/2016 4:07:54 AM • Kenmore Elite... • Answered on Aug 08, 2016
The dryer comes up with 2 codes CLL and Sru. It functions fine, can I continue to use it for a few days until the service rep can make it?
Clean the lint filter and shut down the machine for 5 minutes. Restart and see if the codes clear. If no problem, no worries, just ignore the codes.
4/27/2016 12:18:10 AM • Kenmore Elite... • Answered on Apr 27, 2016
Wont produce heat
U need to check the device responsible for generating heat - if electric it is the heating element(s) - if gas make sure the pilot is lit and there is gas going to the unit.
8/9/2015 9:41:32 PM • Kenmore Elite... • Answered on Aug 09, 2015
Getting F99 code when trying to use delicate cycle
CCU not matched with other electronics in machine. If board was replaced may have been defective from start order new board again this is a e prom problem computer board issue. send new board back for replacement
7/7/2015 8:59:46 AM • Kenmore Elite... • Answered on Jul 07, 2015
How to test thermal fuse?
using a multi meter test both ends of prong for ohms or resistance. a reading of infinity means an open circuit
3/31/2015 12:07:24 AM • Kenmore Elite... • Answered on Mar 31, 2015
Once I press normal dry and press and hold start machine beeps with time remaining flashing
You either have a bad door switch or thermoresister is bad dryer should be flashing a code also check your lint screen make sure dryer is not clogged up check vent going out if thats not problem then its main relay power board
3/24/2015 12:19:39 AM • Kenmore Elite... • Answered on Mar 24, 2015
Converted a kemore from gas to propane now it doesnt get very hot and takes forever to dry
Normally natural gas appliances have a different nozzle size than the propane units. i would check with your propane/gas dealer to make sure.
1/27/2015 7:40:42 PM • Kenmore Elite... • Answered on Jan 27, 2015
2answers
How to remove ink from dryer
None of the chemicals you describe should be used. The heat or spark from the motor could cause a explosion.
Put some old laundry material in there and run it multiple loads with no heat it will eventually wear it off.
11/26/2014 8:06:03 PM • Kenmore Elite... • Answered on Nov 26, 2014
How to clean lint out of a kenmore elite gas dryer?
Professionally Dryer need to be taken apart some. by removing front of dryer and removing inner tub .having a good shop vacuum. and a paint brush .We have a service and charge $65 come out and clean dryer and venting. heavy lint build up in dryer normally means improper venting. all domestic dryer venting should never go over 8 ft vertical venting the less turns the better and if vent go's up you need induced venting another fan to help dryer push air Sears website will have brake down on your dryer not a hard job if your good with tools
7/6/2014 9:58:39 AM • Kenmore Elite... • Answered on Jul 06, 2014
Sears he3 electric dryer flashes F70
This is an overheating issue. The dryer needs to be cleaned at least once a year. This means pull the bottom panel off that is under the door and vacuum out all the lint. Then clean the outlet and duct work that it connects to. There are some other causes but that should take care of it.
6/25/2014 10:32:56 PM • Kenmore Elite... • Answered on Jun 25, 2014
Dryer he3 had power surge will not come on
Low or high voltage can kill the electronics in the dryer controls. Ask the power company to repair as they contracted with you to furnish power at a useable voltage. They have breached their contract with you. If they deny your request, argue breach of contract not negligence.
5/22/2014 1:23:34 AM • Kenmore Elite... • Answered on May 22, 2014
He3 gas dryer not heating
thee a lot compenents in the heat circuit it could be any one of them , starting with the thermal fuse,thermostat, safety valve ,glow bar, and flame sensor
5/12/2014 2:17:21 PM • Kenmore Elite... • Answered on May 12, 2014
0answers
Kenmore Elite HE3 Steam 8674 Dryer Logo
242 questions posted
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Dryers
  • Kenmore Dryers
Most Popular Question
siemens dryer powers but will not
  • Dryers
