20 Most Recent
Amana PTH093B35AM Thru-Wall/Window Air Conditioner Questions & Answers
When was this unit built
If this is the serial number, it is a 1993 model.
Shastalaker7
A/C, & Heating Contractor
4/10/2011 3:51:49 AM •
Amana...
Answered
on Apr 10, 2011
DOES ANY ONE REMEMBER HOW TO PROGRAM A AMANA
Press and hold up and down arrow at same time -press off twice to get into program mode (should read C1) -press heat button to scroll to C2 the use up arrow to scroll through options. You want to set it to read-out "On" then press off to set. This should be the continuous fan mode.
6/15/2010 5:34:37 PM •
Amana...
Answered
on Jun 15, 2010
I'm not getting any code after installing a control board for my Amana ptac?
Does the power light come on?
If yes, then you can do a reset as below:
There is a master switch on the bottom left of the control board. Slide that to 'off' position.
Then press the hot and cold switch/key together and then slide the master switch back to 'on'.
Please put your response/observation here if that does not work or there is power light as asked on top.
Thanks
Amana PTH153B50AM PTAC where the heat runs intermittently.
i'm not familiar with your specific unit but ..sounds like an electronic gas value has gone bad or has a bad connection when that happened to my friend it wasn't that expensive to have it fixed .. BYW it acted like this for a while then stopped working completely
