20 Most Recent Vizio VW32L 32 in. LCD HDTV Questions & Answers
Vizio 32" Channel Scan Issue
The problem is a defective main board, the EEPROM on the board is defective.
6/2/2017 6:54:02 PM • Vizio VW32L 32... • Answered on Jun 02, 2017
I have a Vizio VW32L
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
4/3/2017 11:53:37 AM • Vizio VW32L 32... • Answered on Apr 03, 2017
"No Signal" on channel 9
Appears you are getting a weak signal at the channel 9 frequency. If you are using a signal splitter, try replacing it with an amplified unit since splitters always do the deed but they can and will reduce signal strength significantly. Also remember that digital signals are not like the older analog ones that they replace. They are not subject to ghosting but are weaker and susceptible to all sorts of interference such as a leaf, rain, etc. Your antenna is good. You also might try raising the antenna. The higher it is the better it works. (use some wire to further support additional height) Why do you think transmitters are so tall?!?!?
3/22/2017 4:39:31 PM • Vizio VW32L 32... • Answered on Mar 22, 2017
VISIO VW32L HAS NO IMAGE ON THE SCREEN. WHAT COULD BE WRONG?
T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
12/10/2016 2:59:04 AM • Vizio VW32L 32... • Answered on Dec 10, 2016
2answers
Can a 32in vizio tv be connected to an outside antena
Janice, yes you can hook up antenna. Check the attached links,instruction and guides, Good luck "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." http://cdn.vizio.com/documents/downloads/hdtv/VOJ320F1A/171Manual.pdf How to Hook Up TV Antenna can watch tv on vizio without cable or dtv box How to Connect an Antenna or Cable to Your HDTV For Dummies
8/4/2016 12:56:34 AM • Vizio VW32L 32... • Answered on Aug 04, 2016
Logo amber and white when on no picture cuts off
The Tcon board or the LCD panel is faulty. Can confirm by replacing the TCON board. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
7/12/2016 4:38:39 PM • Vizio VW32L 32... • Answered on Jul 12, 2016
Can I use a universal remote?
Hi Linda: You will need to direct your question to the supplier. I would recommend that you discuss it with the store where you made your purchase.
12/31/2015 6:46:00 PM • Vizio VW32L 32... • Answered on Dec 31, 2015
I've lost about 2 inches at the bottom of the screen and 2" at the top.. ??
Change picture format from letterbox to full screen
12/11/2015 6:31:23 PM • Vizio VW32L 32... • Answered on Dec 11, 2015
Lost owners manual and trying to hook surround sound and need to know where to hookup the amp.
Go up to Visio's website and download a new owners manual
11/15/2015 10:34:42 PM • Vizio VW32L 32... • Answered on Nov 15, 2015
I have a radio shack 3in1 remote i need to program it for a vizio hd tv?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ Search the site by type in the brand name of your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
9/15/2015 1:14:08 PM • Vizio VW32L 32... • Answered on Sep 15, 2015
2answers
Tv turns on but get
make sure you don't have it on energy saver for that if setting up in store
4/16/2015 5:27:50 PM • Vizio VW32L 32... • Answered on Apr 16, 2015
Should i have a built in digital tuner
Your TV does have an inbuilt Tuner. You will need a Digital compatible Antenna. There is a big difference between digital and the old analog TV Antenna's Hope this helps :) Cheers Peter Smith
4/5/2015 8:26:20 PM • Vizio VW32L 32... • Answered on Apr 05, 2015
2answers
My Vizio 32 inch has a black screen. The Vizio
I have had the same problem. I called vizio they told me how to reset my tv. It did not help me, However, maybe it will help you. They said turn the power off, Unplug it hold in power button for 30 seconds then plug it back in and power it back up. My white light flickered and then nothing. So I am going to end up buying a new tv all together.
2/26/2015 7:20:55 PM • Vizio VW32L 32... • Answered on Feb 26, 2015
Vizio VW32L 32 in. LCD HDTV Logo
366 questions posted
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Vizio Televison & Video
Most Popular Question
32in vizio tv connected outside antena
  • Televison & Video
