20 Most Recent Vizio VOJ320F1A 32 in. LCD TV Questions & Answers
I have a VIZIO LCD TV Model voj320f1a, it will not
Is there any sort of reset button on set?
7/26/2017 1:41:18 AM • Vizio VOJ320F1A... • Answered on Jul 26, 2017
0answers
Have no picture or sound why
here is a link for your tv's manual: http://store.vizio.com/documents/downloads/hdtv/VOJ320F1A/171Manual.pdf 1. make sure you have power a. connect a working device such as a clock, radio, or lamp to the wall receptacle to verify power works at receptacle b. confirm power cord is firmly inserted into receptacle and to the tv. c. some appliances have a main power switch in addition to an on/off switch. confirm that if this is the case and make sure the main switch is set to on if applicable. d. check tv to be sure it is powering on. you should see a power indicator illuminate or you may see the screen illuminate and perhaps display a logo screen when it is turned on. If the set is on, operating volume and channel or other functions should display something on the screen. 2. Make sure a working device is connected to your TV and is powered on. a.. if the set is powered on, a source must be connected to the set in order to view a picture and hear sound. you should see connectors on the back of the set for various devices and connections. If you have an antenna, connect it to the antennae connector terminal. you will need to acces the settings to do a channel scan or set up to see any channels you might receive. b..you may have a dvd player or set top box for satellite or cable or an internet streaming device such as a roku to connect. connect the device using the appropriate connectors and cables. once the output of the device is connected to an input on the set, select the input the device is connected to on the set from the tv remote or the side panel buttons and power on the device. hopefully you will see a screen displayed on your tv. if your audio is connected, you should be able to play a video and hear sound. just check all connections to be sure your output connections on your connected devices are attached to the appropriate inputs on your set with the appropriate cables. you may need hdmi, s-video, optical, rca or other cables depending on the device connections and your set connections. c. if you still can not get a picture or sound, try your device with another set and try other devices on your set such as another dvd player or a camera. hope this helps. http://store.vizio.com/documents/downloads/hdtv/VOJ320F1A/171Manual.pdf
4/29/2014 2:53:10 AM • Vizio VOJ320F1A... • Answered on Apr 29, 2014
0answers
No picture
Be the first to answer 1/9/2014 11:20:25 PM • Vizio VOJ320F1A... • Posted on Jan 09, 2014Be the first to answer
0answers
VOJ320F will not power on
If total dead it needs to be safely opened and the fuse checked and or the power board inspected for damaged parts or puffed up filter caps.
12/6/2012 12:58:50 AM • Vizio VOJ320F1A... • Answered on Dec 06, 2012
When I plug in the power, my vizeo logo
This problem indicates that your power supply is faulty it produces dc supply but not enough to transfer other parts. The cause of this is the capacitor or the transistor. If your power supply has a bulge up in the top of the capacitor or not perfectly flat like the others you should replace them because it cannot filter the dc supply and low dc output. Next is the driver transistor if they are leaky it will do the same problem to your power supply. try to test the small transistor beside the regulator. I hope that this may help you regards.
7/30/2012 10:20:59 PM • Vizio VOJ320F1A... • Answered on Jul 30, 2012
Black screen on VOJ32o1A
Check and replace the back light inverter board. Check CCFL lamps too.
7/30/2012 4:27:14 PM • Vizio VOJ320F1A... • Answered on Jul 30, 2012
Blue screen with NoSignal message
HelloAs the set sys, it gets no input signals at all. Just check the input cables.
3/5/2012 3:26:11 PM • Vizio VOJ320F1A... • Answered on Mar 05, 2012
Have vizio voj32f1a that has a cracked lcd panel.
You can try www.encompassparts.com . The display will cost as much as a new set, sorry to say.
6/26/2011 12:28:38 PM • Vizio VOJ320F1A... • Answered on Jun 26, 2011
I HAVE A 32" VIZIO LCD I PURCHASED 2 YEARS AGO.
You should buy a sodering kit and remove the buldging capacitors yourself. Find a local electronics store, I used Radioshack, and see if they can match the capacitors. I had this happen with my Samsung lcd about a year ago and just help another friend with the same issue yesterday. The sodering is not as hard as you'd think. The capacitors should be under $5 v. paying a few hundred for the power board.
3/21/2011 8:30:24 PM • Vizio VOJ320F1A... • Answered on Mar 21, 2011
Need dish network code for
Hello, you may have already gotten this working, but if not, or if you have questions, I have provided some answers. Just follow the link below, and you will be good to go with that remote soon!!!
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Becki Barned
DISH Network Customer Service
1/19/2011 3:55:49 AM • Vizio VOJ320F1A... • Answered on Jan 19, 2011
Vizio VOJ320F1A 32 in. LCD TV Logo
32 questions posted
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
VO Vizio
  • VO Vizio
Most Popular Question
black screen voj32o1a
  • Televison & Video
