20 Most Recent Toshiba 37AV502U 37 in. LCD HDTV Questions & Answers
If indict or light is there, check its main power supply regulator board. replace its or replace damaged component/s. If you wish to get some details, http://electronicshelponline.blogspot.com/Pull up older posts.
Toshiba 37AV502U... | Answered on Dec 22, 2013
Deffective system ic.For repair and replace system ic.
Toshiba 37AV502U... | Answered on Feb 04, 2013
The problem is most likely the the screws are loose on the inverter boards. The screws must be tighted as they provide the ground to the inverter bds. The inverter boards are undet the shields on both sides of the unit after pulling the back cover. One way to make sure that you are losing back lights and not video is when your picture goes black, shine a flash light on the screen at an angle and will see the video is still there. This mean the back lights are out. If you do not see the video it may be another problem
Toshiba 37AV502U... | Answered on Nov 03, 2012
First of all, thank you for posting your question here at Fixya.
Please email me at jimvincentvillanueva@yahoo.com, I will send to you the copy of Toshiba 37AV502 schematic diagram. It is a PDF file format and can't be uploaded here.
Have a great day!
Jdvillanueva
Toshiba 37AV502U... | Answered on Aug 23, 2012
have some to check it for you you might have a power supply problem
Toshiba 37AV502U... | Answered on Jun 04, 2012
best way is to call whoever made the set for length, thread type and number of bolts.
Toshiba 37AV502U... | Answered on May 14, 2012
Yes there is a tale tale sign that you have a blown fuse in the power supply or at least the components inside are not working in order.
A bad power supply would mean a dead TV. Now this does not mean you thorw the tv in the trash and forget it exists. You can purchase the power board itself from www.shopjimmy.com or www.partstore.com. I have seen many people repair these and know nothing about them for under $100 bucks. Not all results are guaranteed tho it will depend on your knowledge.
No stand by light, means no power is being delivered to the TV, Bad power supply or fuse.
I hope this was helpful,
Kind regards,
rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Toshiba 37AV502U... | Answered on Jun 15, 2011
Try some contact clean on the Vol- and Vol down contact switches,either the Vol- contact is dirty or it needs to be replaced. Mats Electronics has contact switches 1-800-628-1118
You could have a problem with Poor Solder Connections on Boards.
Toshiba 37AV502U... | Answered on Apr 12, 2011
Are you sure you are pressing the Power button, and not the Home button?
Toshiba 37AV502U... | Answered on Mar 01, 2011
Solid color vertical line? If it is, then the LCD panel is bad. It will get worst with more lines.
Please look at the picture in my LCD TV torubleshooting guide to see if that is what you are seeing.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Toshiba 37AV502U... | Answered on Jan 23, 2011
IF THE MENU LOOKS CORRECT THEN IT WILL BE A MAIN BOARD FAILURE IF THE MENU LOOKS GOOD THEN IT COULD BE T-CON BOARD FAILURE. CHECK ALL CONNECTIONS BEFORE AND AFTER THE PARTS ARE REPLACED.
Toshiba 37AV502U... | Answered on Dec 17, 2010
between 6.3 and 7 amps should be fine. what board is the fuse on?
Toshiba 37AV502U... | Answered on Sep 03, 2010
Toshiba 37AV502U 37 in. LCD HDTV Logo
46 questions posted
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
lightning struck electrical pole down
  • Televison & Video
