20 Most Recent
Genie Garage Door. SilentMax 1000 3/4 HP Comparable Belt Drive Garage Questions & Answers
Door opens randomly on its own!
can you change the toggle switches in the remote and door controller to a different code than it is set on now. Like the two devices must match but hopefully the neighbor code for their door will then be different. Also can you change the frequency ?
Overhead light will not go off
need to replace light contact inside of genie they have welded themselfs togaether and need to be open for light to go off
What is a meat tenderizer?
This is used to tenderize meat before you cook it. It makes the meat easier to chew and digest. You can also use it before you boil or fry meat. You can do this mechanically, with something like a meat mallet that cuts up the meat fibres. You can do it thermally by putting the temperature really high to break down the connective tissue of the meat. The last method is enzymatic and uses enzymes to break down the collagen. This method is either slow with dry-aging the meat or you can use fruit to marinate the meat.
4/16/2024 6:28:01 AM •
Home
Answered
3 days ago
