20 Most Recent Sanyo DP32648 32 in. LCD TV Questions & Answers
2answers
I have RCA remot and sanyo Tv need the COODES. Thanks
0271,0295,0229. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box. http://electronicshelponline.blogspot.com/ http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/
12/6/2022 5:27:01 PM • Sanyo DP32648 32... • Answered on Dec 06, 2022
0answers
0answers
I lost my remote on my dp32648 32" flat screen
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
9/11/2016 4:00:45 AM • Sanyo DP32648 32... • Answered on Sep 11, 2016
Green light comes on but nothing else. Could it be a fuse or inverter board?
Do you have sound? If you look closely at the screen with a flashlight can you see images?
5/12/2016 2:59:04 AM • Sanyo DP32648 32... • Answered on May 12, 2016
Sound but faint picture
Hi Neil, It a case of backlight failure. Most probably the inverter board has gone bad. Good Luck.
5/10/2016 10:35:14 PM • Sanyo DP32648 32... • Answered on May 10, 2016
WHE I TURN ON THE T.V THE T.V LOOKS OK , BUT AS IT HEATS UP ,, MY COLOR STARTS TO MESS UP AND THE POCTURE STARTS. DISTORTING , CAN YOU PLEASE LET. ME KNOW
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
4/17/2016 6:58:10 AM • Sanyo DP32648 32... • Answered on Apr 17, 2016
I need remote codes for a sanyo dp32648 tv
which remote do you have?
3/19/2016 1:24:04 AM • Sanyo DP32648 32... • Answered on Mar 19, 2016
When I turn off my tv for an hour or more then turn it back on I get the blue hdmi signal then screen goes black but I can still hear sound but no picture. after turning off and on several times I fi
Likely you have a heat related issue in the tuner. The picture cutting out is related to the tuner board over heating and signalling the power board to switch it off. The solution is to get better heat control on your TV. Try using a fan to see of this improves anything, and get a better ventilation to your tuner.
1/2/2015 4:39:01 AM • Sanyo DP32648 32... • Answered on Jan 02, 2015
Why do my tv turns off when i turn it on ?
Maybe the switch is put in backwards. You have to be more specific please.
1/2/2015 4:18:41 AM • Sanyo DP32648 32... • Answered on Jan 02, 2015
Need a pedestal stand for DP32648 tv
there are to many sites for this product and 95% of them dont sell the product i was looking for a tv base for the dp 32648 Sanyo should just sell this product in the store or make is easier to order this is crazy when you cant find a product in this day and age
10/3/2014 1:15:47 AM • Sanyo DP32648 32... • Answered on Oct 03, 2014
Shuts off and will not come back on
its your main board took me forever to get to the bottom of that issue myself. there is a control heat sensor something cant remember the name on the board. mine would work for a few hours then just shut off and not come on for 12 hours. this is how you fix it. first off take the back panel off the one on the right that about a 1 by 1 foot then you will see the power supply and the board that the cable and other hook ups go to. so put a fan that just blows right in there. if it stays on much longer or doesnt shut off most liklely 90% it the main board. now im a computer tech and i work with boards all day long and have a few tricks. take your main board out and clear off a nice spot in the freezer and leave it in there 2 to 3 hours, leave out of tv over nite then reinstall. mine works fine now. the board to replace is not worth it hope that helps..
7/15/2014 1:06:04 AM • Sanyo DP32648 32... • Answered on Jul 15, 2014
0answers
My Sanyo DP32648 was plugged into a surge
If you look at the power supply board as shown in the picture: http://assets.shopjimmy.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/s/j/sjdps153ap1a.jpg
There is a main fuse on the top left of the board covered by black shrink tubing, SLO-BLO 4A 250V. Check it out to see if it is blown.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
4/9/2014 11:37:14 PM • Sanyo DP32648 32... • Answered on Apr 09, 2014
Sanyo DP32648 32 in. LCD TV Logo
141 questions posted
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sanyo Televison & Video
Most Popular Question
sanyo tv dp32648 play s in whit no color
  • Televison & Video
