20 Most Recent Sony KLV32S400A 32 in. LCD TV Questions & Answers
2answers
Is sony klv32-a400a is a led or lcd tv
An LED TV is still an LCD TV, just with LED backlighting. That model is an LCD TV. The difference is in the backlight. Both LED and LCD TVs use an LCD screen. LED TVs have LED backlighting of the LCD screen, which saves energy.
1/3/2020 11:21:38 PM • Sony KLV32S400A... • Answered on Jan 03, 2020
I have tha LCD TV
Sounds like T'Con board fault. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size. Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
1/21/2018 4:19:17 PM • Sony KLV32S400A... • Answered on Jan 21, 2018
Sony klv 32s530a lcd tv program sound ok no pitcure but backlight ok
unplug everything and test one input device at a time (ie, game console, computer, tv, cable, etc) and select the appropriate input for whatever you plug in. could be the device being plugged in and not the tv at all. Also, do you get a menu when you press the menu button on the side of the television? If so, true, backlight could be okay.If all this fails, turn off and unplug tv, remove rear panel, and, one at a time, unplug and plug in every connector jack (cables) that you can find on the back of the unit. check for loose jacks/connectors, smell see if anything smells burnt. Lastly, try not to electrocute yourself when inside the tv.
11/23/2017 8:13:29 PM • Sony KLV32S400A... • Answered on Nov 23, 2017
Had a power surge on this tv model klv32s400a, no standby led completly dead. Have opened and checked the power supply as far as I can, supply is present on primary side of transformer but not getting
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size. Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
9/10/2017 2:37:19 PM • Sony KLV32S400A... • Answered on Sep 10, 2017
Tv white screen
Problem is with Tcon board mounted on the LCD panel. Either replace Tcon board in complete or try to replace IC AS15-HGXXXXX mounted on Tcon board.
3/4/2014 4:40:17 PM • Sony KLV32S400A... • Answered on Mar 04, 2014
0answers
0answers
Suddenly switched off and red light blinking
hi sounds like a power supply fault, could be capacitors look for a tech in your area regards shaun
1/25/2014 3:12:45 AM • Sony KLV32S400A... • Answered on Jan 25, 2014
0answers
0answers
Brightnes too high
Using the remote that came with the TV, you should be able to bring up the MENU on the TV screen. You will have several options to work with, one of which is setting up the screen. One of the options offers you screen brightness. Slide the value pointer along the bar to the desired brightness. All of this is detailed in the setup manual that came with the TV.
12/25/2013 4:07:21 AM • Sony KLV32S400A... • Answered on Dec 25, 2013
Brighnes too high solution
Hi Oguis, Do you get variation in brightness or the minimum brightness is too high?
12/25/2013 3:13:07 AM • Sony KLV32S400A... • Answered on Dec 25, 2013
SONY KLV32S400A - picture has become dark, faces on screen cannot be seen
Check the voltages that comes to the back light inverter, especially, the voltage from the main digital board that controls the brightness. If is found OK, be sure that the backlight inverter board is faulty. If not, the main baord. If you wish to get some details, check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/
12/13/2013 12:40:00 PM • Sony KLV32S400A... • Answered on Dec 13, 2013
Sond ok back lit ok but no display
can you connect to a tv or another monitor???try this see if works;if not the problem is with the graphics if you can get picture on a tv monitor check the device manager..(right clik start control panel-device manager)if any items have a yellow triangle there is a problem.
12/12/2013 7:47:26 PM • Sony KLV32S400A... • Answered on Dec 12, 2013
32 inch replacement power supply board, what is the cost?
It will be best to buy its original power supply board. Contact the authorized service center for Sony.
11/12/2013 3:28:05 PM • Sony KLV32S400A... • Answered on Nov 12, 2013
Sony KLV32S400A 32 in. LCD TV Logo
75 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
  • Televison & Video
