20 Most Recent
AOC 917Sw 19" LCD Monitor Questions & Answers
Displays for a second, then black screens?
old monitors all made before mid year 2010
are all CCFL backlamps and most died 5 year old
10/hr. per day and EOL hits..end of life.
the problems is not the cure we well know the problem is econ101
spending $200 to fix a $20 dead (sold for parts0 monitor is bad econ.
see page 5, here
https://www.manualslib.com/manual/798783/Aoc-Aoc-917sw.html?page=5&term=inverter&selected=1#manual
CCFL *****
this what they all did long ago, if actually used heavy
- CCF go dim
- go intermittent. (PURE RANDOM) 'Ionization is tricky""
- goES dead
- goed dead only hot or cold (yours fails warm)
- goes yellow tinged for pure white.
- IF 2 TUBE BANK OR UTUBES, 1/2 GOES DEAD.
RIP one more of millions now dead, most are, unless hanger queened (nos) or was in sleep mode most of itS life,
at 20k hours of real use they die. (MEANS GLOWING)
We have purchased two e950Sw
you will need to down load drivers for the monitors
get them from the monitors manufacturers web site down loads
Aoc monitor shows error message while connecting with i ball tv tuner
What resolution is the AOC monitor capable of using?
What is default resolution of the device you are connecting?
If the default is 1080P and the monitor is not 1080P capable then that would be your problem. You could attach to another monitor or HDTV and possibly turn down the resolution then try again.
Osd Lock how to open?
1) Press the MENU-button ( ) to activate the OSD window.
2) Press or to navigate through the functions. Once the desired function is highlighted, press the MENU-button to
activate sub-menu . Once the desired function is highlighted, press MENU-button to activate it.
3) Press or to change the settings of the selected function. Press or to select another function in sub-menu .
Press AUTO( ) to exit . If you want to adjust any other function, repeat steps 2-3.
4) OSD Lock Function: To lock the OSD, press and hold the MENU button while the monitor is off and then press power
button to turn the monitor on. To un-lock the OSD - press and hold the MENU button while the monitor is off and then
press power button to turn the monitor on.
5) Eco Mode hot key ( ) : Press the Eco key continuously to select the Eco mode of brightness when there is no OSD (
Eco mode hot key may not be available in all models).
6) Volume adjustment hot key : When there is no OSD , press Volume ( ) to active volume adjustment bar, press or
to adjust volume ( Only for the models with speakers).
http://www.retrevo.com/support/AOC-917SW-Monitors-manual/id/23449ag008/t/2/
http://s807.photobucket.com/home/budm/allalbums
The screen flickers when I am playing games
If it's a few years old the power inverter could be going, otherwise it likes to run at the "native resolution" all monitiors have a "naitive resolution" i just means the resolution that the manufacturer recomends. It should be in your booklet, also diagnosing games is tough because they are graphic intense. There is a site called "can I run it" that will tell you if your machine can run specific tests. I play Call of duty modern warfare, And with dual SLI video cards I just about run it, with a dual core and 2 gigs of ram. This is subjective at best. also the refresh rate on your monitor plays a big role in these games, anything slower than 5ms is too slow for most new games. Mine are 1 and 2 MS. check the box ou the game it will tell you the minimums
AOC monitor black screen how do I fix it?
I have a couple AOC i2353ph monitors. One day, one of them booted up with a single vertical white line moving slowly back and forth across the screen that kind of looked like a scan or radar. Once I reset the monitor from the OSD it went way. Use "Extra > Reset" from the monitor menu.
