20 Most Recent Apple iMac G4 20" Mac Desktop Questions & Answers
Bigpond Email Customer Service Call 1-805-225-6690 We are 24 Hour Available Call Now for Help
Sorry you are having this problem,
Sounds to me like your eMail client configuration is incorrect...
Is this a new problem where you were able to send an receive mail no problem before and now this ?
I suspect it is a new set-up.
It looks like you entered your eMail address where the software was asking for the address of the SMTP mail server...
Port 465 is for a secure SMTP Server.
Normally, the SMTP server port is 25 or 26. Have you modified your eMail settings lately ? Or maybe it works well from home but not when you are on another network....
Bigpond has implemented some security on their network, see here:
http://bigpond.custhelp.com/cgi-bin/bigpond.cfg/php/enduser/std_adp.php?p_faqid=5562
So, when you are connected to the bigpond network, you must use their SMTP server:
mail.bigpond.com
Otherwise, it will reject the connection.
When you are away from the bigpond network, you might have to ask your host or whoever, who provides the highspeed internet access ? and then google for their smtp server,
ex: securenet.net smtp server earthlink smtp server
you will quickly and easily find this server and all you have to do is enter it temporarily into your SMTP server field in your eMail client settings making sure to set it back to bigpond once you are back home..
THis should get you back on your way again.
11/7/2019 2:30:36 PM • Apple iMac G4... • Answered on Nov 07, 2019
Lines appearing on screen.
mcdevito75 here, Hopefully it"s just bad cinnection, Check all connections at the monitor and computer, If good, press the AUTO button on your monitor, this returns screen to factory settings. If all this fails, your monitor may be going bad. Take the monitor to A Staples, best but or computer repair shop for a check out. Hope this helps.
9/9/2014 12:22:20 PM • Apple iMac G4... • Answered on Sep 09, 2014
Imac external HD problem
You do not have permissions set up correctly.
12/26/2013 11:50:39 PM • Apple iMac G4... • Answered on Dec 26, 2013
It will not power up. Have unplugged everything
Power supply.
12/26/2013 10:20:53 PM • Apple iMac G4... • Answered on Dec 26, 2013
How do I disable bluetooth on my imac
Go to system preferences and then under internet and wireless there is a bluetooth icon click on that and then uncheck the on box. Hope this helps.
11/8/2013 10:37:45 AM • Apple iMac G4... • Answered on Nov 08, 2013
2answers
Can't read emails
Try a different computer to sign in. Go from there
10/17/2013 4:44:42 AM • Apple iMac G4... • Answered on Oct 17, 2013
My imac g4 goes to white screen on start up. The
I think your system files are corrupt try to reinstall mac OS X
6/9/2011 12:22:31 AM • Apple iMac G4... • Answered on Jun 09, 2011
Cannot burn cds
Go into system profiler and see if your cd drive can perform burnning?
6/8/2011 11:50:24 PM • Apple iMac G4... • Answered on Jun 08, 2011
IMac 20 inch flat panel will no longer startup.
Do not know where you are located but in the uk I used http://www.applemacparts.com you can locate parts there. Hope this helps, if you are outside the UK you could contact them to see if they have any other sister companies around the world.
2/14/2011 7:40:24 PM • Apple iMac G4... • Answered on Feb 14, 2011
When i scroll with mouse the whole screen moves
What you have done is accidently magnified your screen slightly. To correct this hold down your ctrl key and scroll down on your mouse, this should fix it. Hope this helps.
8/29/2010 10:07:14 AM • Apple iMac G4... • Answered on Aug 29, 2010
Kensington cable lock
Kensington lock slots are universal. Any Kensington or similarly branded laptop/computer lock will fit any iMac, and Macbook, Macbook Pro, Mac Mini, or Mac Pro.
8/20/2010 2:09:41 AM • Apple iMac G4... • Answered on Aug 20, 2010
2answers
I have a I mac computer, i have done a speed test
It is very easy to check the speed of the internet connection using http://www.ip-details.com/ , by doing this may help out what as went wrong with your laptop.
8/16/2010 5:45:46 PM • Apple iMac G4... • Answered on Aug 16, 2010
Email hijacked
This is indeed unique to just Facebook. Facebook has a number of privacy settings that you can change to make it less likely that you will have your security compromised in the future.
Your first step would be to immediately change your password.
After that, I very strongly recommend using the following easy-to-use webpage to scan your privacy settings and change them using the on screen instructions to be as secure as possible.
7/7/2010 8:05:00 PM • Apple iMac G4... • Answered on Jul 07, 2010
Mac desktop computer
To reset your password without knowing what it is requires the installation discs that came with your computer originally. The steps on how to do so are detailed in the following article:
http://support.apple.com/kb/HT1274
You will need to follow the instructions in the 'Resetting the original administrator account password' subsection.
Please note that if you do not have your installation discs you can contact Apple to re-order them at 1-800-MY-APPLE.
7/7/2010 8:02:06 PM • Apple iMac G4... • Answered on Jul 07, 2010
My imac safari can no longer open google. it can
look at the browser tools at the options ..under security ..or interdictions ...Im not sure at Mac ...it is for sure added by mistake on the list with blocked sites..
4/27/2010 4:50:51 AM • Apple iMac G4... • Answered on Apr 27, 2010
HOW DO I DOWNLOAD INTO MY COMPUTER?
friend all the things download in local drive.. please describe your problem in details.
4/1/2010 6:02:55 AM • Apple iMac G4... • Answered on Apr 01, 2010
My imac is not letting me browse the web. Problem
Did you contact your internet provider?
3/27/2010 1:39:14 PM • Apple iMac G4... • Answered on Mar 27, 2010
My wife's G4 20" Flat
Chances are you have some Bad capacitors its the most common problem for LCDs Look for any capacitors that are puffed up on top if you find any replace them they are Bad 1000uf 16 or 25v ,2200uf 25v caps.for capacitors Call Mats 1-800-628-1118
12/6/2009 1:45:23 PM • Apple iMac G4... • Answered on Dec 06, 2009
Apple iMac G4 20" Mac Desktop Logo
38 questions posted
Popular Products
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
iMac Apple
  • iMac Apple
Most Popular Question
when scroll mouse whole screen moves
  • Computers & Internet
