20 Most Recent
SNK Magnavox 32MF338B27 32 in. LCD TV Questions & Answers
No power fuse blew
it means you have shorted regulator transistor on power supply..It is usually fit in heat sink..Try to replace it and the fuse again also check any fusible resistor near that transistor..
Magnavox 32MF338B27 will power on
hi,
There is no such screen server option in this tv. check one thing when the colours cycles on the screen press the menu button and watch is there is menu screen appears. If not then the tv have problem withi its mother board. If the tv is in warrenty then it will be better to consult the autorised servicing center.
Try to reset the picture setting before going to servicing center. For that swich ON the tv, Press the menu button and select Picture . In picture setting select Reset picture setting and press OK button. This will make all the picture setting to factory default. You have to do this within that one minute. If then also tv shows the same problem then you need to consult the servicing center of Magnavox.
OK
When plugged in, no power, no red led light
U check the power source?Yes,than the power supply board is the problems and the causes.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I own a magnavox 32MF338B27
If youre looking for an audio output , it's digitally encoded.
Try connecting your incoming signal to an A /V receiver 1st ( if you have one)
Then drive the sound bar and sub with the receiver
Tv turns off seconds when turned on
I have not repaired this particular model. But the symptoms on similar ones was the inverter board. Have a TV tech inspect the inverter board. Thanks for asking!
TV will not power on
Yes,power supply board have dead capacitors leakage problems.These capacitors useally bulge up or burst open.U know how to solders?Look in the power supply board rerplaced these capacitors will solved the power problem.Or tries Websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
I have a 32" Magnavox LCD that works, then doesn't work.
Resolder or replace Main Board it is the board that you hook cable up to. For Parts /Prices moduels Call Encompass Parts Distrubtion 1-800-638-3328 Firts try resoldering board and look to see if you have any capacitors that are starting to puff up on top if you see any that look like that they need to be replaced Call Mats Electronics for Parts/supplies
capacitors,etc... 1-800-628-1118
