20 Most Recent
SNK Skyworth SLC1963A 19 in. LCD TV/DVD Combo Questions & Answers
Why dvd player want work
Disc loader mechanism fault. Either a broken belt, damaged loading motor or any gear wheels can poise this problem. Contact any service technician. The mechanism should be take out from the set for repair.
Discs inserted does not loading properly to exact seating; is the problem.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Do a search by type in the brand name of your device at its search box and press "Enter".
Lock key
Channel locked. Refer the user manual for details about to unlock channel.
My skyworth 15.6in flat screen
check the input selection on menu of tv, it may be trying to read dvd player without dvd inserted or another device connected to tv. also check to make sure cables are secure,. Most likely it is on wrong input.
Wont change input
sounds like the volume up button is stuck on the tv , try fiddeling with it on and off , because it is locked down the other controls will not function
