20 Most Recent
Sony BRAVIA KLV-37U300A 37 in. LCD TV Questions & Answers
Display not clear
You should buy its genuine board, and to get it, contact the authorized service center for Sony. Never attempt to replace a board not genuine, to this TV. Especially to Sony and Philips, the original replacement should be done; other wise it might poise other severe problems. If you wish to get some
details, check the site linked here. Pull up older posts.
Hi Expert,
Both remote control
Hello
If both remotes are not working with your tV, the infrared sensor inside your TV is faulty. It should be replaced with same type andnumber. Infrared sensor can be located just behind the infrared window on the front of your TV. It will be soldered direltly to a board, and can be detacted out from it. You have to open your TV, and locate this component. It will be in bronish black in colour and will have three solder terminals. The number will be printed on its body, either by ink or by laser print. Note the number, and it iis very inportant when you repalce it. OK.
For a KLV-37U300A
The infrared pickup is usually on a separate printed circuit board near the front bottom edge, but it may not be simple case of just replacing the board, even if you can find a replacement for it (this is not an off-the-shelf item). There could be a fault anywhere in the circuit from the pickup to the microprocessor. Unless you have experience with electronics you should take the TV to a reputable TV repair shop in your area.
If you still want to look for obvious faults yourself then you need to remove the back cover WITH THE POWER LEAD REMOVED FROM THE MAINS. There may be one or more dry joints. Look for capacitors with bulging tops. Check all lead connections with a multimeter.
Be advised that if you are not familiar with electronics then you could cause more damage so be careful.
Sony Bravia 46 XBR has the input bar stuck at the top of screen.
Unplug the TV for a while and hopefully, that should reset the circuity. If you're using the original remote control, check for the display button and press it.
I would also suggest doing a factory reset if your TV has that feature and if the TV allows you to do it after unplugging it.
I need to remove the back off a Sony Bravia KD-48X81J
The front and back pieces are like a clam shell and are compression fit with tabs into one another. You need to use something like a guitar pick or spudger to separate the pieces. Dont use metal objects due to damage that will happen to the plastic .
How can I watch Netflix on a tv Sony wega that isn’t hooked to the internet. It’s wirelessly connected to Vizio ( smart tv Netflix built in) but I want to be able to watch in a different room
netflix is a 100% internet web site , streaming site.
thus the net in flix.
what did you mean by hooked?\
do you have internet at home at all?
do other things in home work to the internet, like PC or cell phones.
what I can not under stand is (different room) this phase
implies some rooms do work (netflex)
and wifi gets weak if my move any TV farther from the home router
and will fail past 25 feet or more. wifi is super weak through walls
for sure brick, or 2 walls.
if home is small one wifi access point is all you need
if huge home more.
distance matter, TV to router.
no TV model # told. (tells me wifi spec)
if you said my TV works in room 1 but not room 2, wifi;.
it be super more easy to answer.. is this true?
if true , get a tech to upgrade your wifi.
or go wired, Ethernet.(a better home upgrade)
