20 Most Recent Toymax Viore 42 in. Plasma TV Questions & Answers
2answers
Hi , was watching my 42 inch VIORE Plasma TV last
Check high voltage circuit. This is near where the 120 volt cord is plugged in and a high voltage transformer, where there should be capacitor (or two). Check the voltage - should be 390 to 400 volts. If not less than 390, near to replace the capacitor.
12/23/2017 2:12:42 AM • Toymax Viore 42... • Answered on Dec 23, 2017
Model#pdp42v18ha power on black screen indicator light works cuts off in 5 seconds
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electro-medical.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
3/3/2016 6:47:37 PM • Toymax Viore 42... • Answered on Mar 03, 2016
Viore 37" LCD- Green Tint...no TINT setting available to change
change the main board
10/19/2015 2:08:06 PM • Toymax Viore 42... • Answered on Oct 19, 2015
Viore tv with no signal when hooked up to cable? I
I brought a viore from a yard sale and now I can not seem to set it from cable to antenna what can i do
9/15/2014 10:20:59 AM • Toymax Viore 42... • Answered on Sep 15, 2014
Voire 46" plasma tv- best color settings, to much white
The proper way to set flat screen tv's is opposite of old school CRT tv. First, find a movie with dark scenes and pause on a really dark part. Now set brightness only high enough to see some detail - no more. then go to a really bright scene and set contrast just high enough for good brightness. You may need to go back and forth a few times to get good setting.
6/22/2014 12:35:06 PM • Toymax Viore 42... • Answered on Jun 22, 2014
My viore tv wont start
service ur set
2/26/2014 7:49:18 PM • Toymax Viore 42... • Answered on Feb 26, 2014
Flashing picture
Sounds like main board fault. Contact any "Experienced" service technician, or, the authorized service center for Viore. Gopakumar Gopalan Google
2/25/2014 6:47:31 AM • Toymax Viore 42... • Answered on Feb 25, 2014
0answers
LCD32VH56A
Be the first to answer 12/24/2013 3:15:43 AM • Toymax Viore 42... • Posted on Dec 24, 2013Be the first to answer
I can plug the viore tv into power supply but the
There is something wrong with the voltages out [low voltages] from the main power regulator board. Check it. If you wish to get more details, check this site. http://electronicshelponline.blogspot.com/ Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
9/19/2013 8:20:41 AM • Toymax Viore 42... • Answered on Sep 19, 2013
2answers
Viore 42 inch tv PD42Vh80 had no sound but great picture HDTV
speakers switched off?volume on set or a box down or muted? check both the set and box.Does the set have normal sound when playing a DVD etc via the audio and video jacks on the rear or side?
8/28/2013 5:57:13 AM • Toymax Viore 42... • Answered on Aug 28, 2013
Toymax Viore  42 in. Plasma TV Logo
101 questions posted
Top Toymax Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Toymax Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toymax Televison & Video
Most Popular Question
model pdp42v18ha power black screen
  • Televison & Video
