20 Most Recent
Microsoft Flybook V5 Tablet PC Questions & Answers
My flybook batteries are not charging. What can i
FLYBOOK EXPERT HERE
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE
REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
1/19/2011 11:04:06 PM •
Microsoft...
Answered
on Jan 19, 2011
Hi
I have a flybook 3G
Where are you exactly located? you can order battery directly to flybook company or you can contact at www.memega.com
10/31/2010 9:07:38 AM •
Microsoft...
Answered
on Oct 31, 2010
T,h,y,5,6 keys on my keyboard don't work, have to
Hi
Try compressed air to remove the dirt and dust underneath the keys. If it does not work then it’s a spyware issue, try downloading freeware program to find and eliminate it. Hope that will work.
laptop have a lot of various switches to turn stuff on or off if you press the right combo of keys try pressing you Fn function button down and try the keys that are not working .
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
7/3/2010 1:09:22 AM •
Microsoft...
Answered
on Jul 03, 2010
Hi, I was having a
Uninstalling the drivers and then installing them again should return everything to default values.
so you can uninstall the software / drivers from start -> control panel -> uninstall programs / add or remove programs, find it from the list and uninstall. if noting related is on the listen then icnore this step and go forward to the next one.
on your desktop or on your start menu, right click on my computer or "computer" click on manage from the menu that comes up.
on the computer management window on the left side, click on device manager, then see on the right side, video adapters or display adapters or similiar, open it up from the + next to it, see your video adapter there? Right click on it and uninstall.
make sure all video adapters (most likely just one) are uninstalled, then restart the computer, it should start up in basic video settings and you may have to get the drivers for the video card from the makers website (I can look them up if you send me the brand and model of the laptop)
All the settings will return to normals and the hardware acceleration should be turned to full, and you should be able to adjust it again.
7/25/2009 12:12:04 AM •
Microsoft...
Answered
on Jul 25, 2009
Microsoft surface 3 charging
You should have had in the box with your Surface 3 Tablet a charger. It will have a plug with 2 points that is for your power plug, and at the other end you will have a natty little flat magnetised plug for the side of your Tablet. Mine is at the bottom right slot, looking at the screen of your Tablet. Now when the power is turned on, a small bright light will glow. That is now informing you that the battery in your Surface is being charged. Now at the bottom right of your Task bar, that is the Bar on the bottom of your screen where you can place program short cut Icons for your convenience. Now the speaker Icon which is there toward the right-hand side and has a cross if off, or a different look when on. Now the next icon on its right is the one that tells you how much charge is in the battery, if you touch it, it will come on to the screen informing you how much charge you have in the battery. If I'm using my Surface a lot and I do I keep it on charge while I work as a precaution to keeping my Surface well topped up. Hope this helps.
3/12/2019 10:14:08 PM •
Microsoft...
Answered
on Mar 12, 2019
I want to install Microsoft word on my ipad
Hi, you may have to go to the Microsoft home site, and ask for Microsoft Word or Office for iPad. There is one for both Apple and Android systems, but it is a little different to the one they have in their own Windows system. I use Open Source from Oracle it's free and it works well in my Windows 10 machine and Surface Tablet. Best of luck.
1/13/2019 12:09:56 AM •
Microsoft...
Answered
on Jan 13, 2019
Need to reset a digiland dl808w tablet NO TOUCHSCREEN
I know how fix it if any still need help. You will need usb with windows 8 install on it, keyboard and micro usb hub, which take other devices get things from it, like gettin gwindows 8 start on tablet digiland. You need start device, press winodws key and alt, then it should start over bios mode, then go to first slot start windows 8 usb, then restart, wait it fully go usb then should be windows 8 install done right after waiting say 5-8 minutes see it, then should be able take it from there. I did it but having problems with updates it needs, which working on. Hey least get winodws 8 right.
5/20/2018 4:22:31 AM •
Microsoft...
Answered
on May 20, 2018
WILL APPLE FIX MY IPAD AIR IF IT DOESNT CHARGE FOR FREE
Apple only fixes it's products for free during guarantee period (mostly 1 year, 2 years with Apple Care Protection Plan), but before you send it to Apple check your charger, you need at least a current of 2Amps. If this is ok, check if the charger can charge other devices. If yes, go to a store selling iPads and check if you can charge your iPad with the charger of one of the sample products.
8/12/2015 1:13:16 PM •
Microsoft...
Answered
on Aug 12, 2015
