20 Most Recent Motorola Talkabout T5720 (7 Channels) 2-Way Radio Questions & Answers
2answers
How to open the T5720?
for 5720 - open two screws below battery compartment. and two screws are under the front false faceplate. Pull out the face plate (from the top) and unscrew the two screws above the display. walla you have it dismanteled ! Arshad
5/31/2020 9:02:32 PM • Motorola... • Answered on May 31, 2020
Sends well but will not receive unless mon is
Perhaps the monitor button is over-riding a privacy code. Set the privacy code to zero and then try it again.
11/18/2017 5:46:46 PM • Motorola... • Answered on Nov 18, 2017
One radio receives and transmits
You're not trying to use a privacy code on one radio without using the exact same privacy code on the other radio, are you?
11/18/2017 5:45:13 PM • Motorola... • Answered on Nov 18, 2017
I have a set of Motorola T5720 walkie Talkies. I cannot determine if one of them is not receiving or the other is not transmitting.
One radio works properly, the other can receive. I assume there are more than two by the question. Check and then rotate you batteries, mark on the working unit battery that it is GOOD. Transmit takes a great deal more power than receiving. Batteries, even un-used only last 18-24 months typically. If no joy, then check your programming but I think that is unlikely. It really sounds like a power/battery issue.
9/4/2016 5:09:26 PM • Motorola... • Answered on Sep 04, 2016
Talkabout t5022 cannot talk with t5720 how do I
Look for the user guides here http://shop.giantintl.com/Manuals.asp?offset=30
12/17/2015 12:35:36 PM • Motorola... • Answered on Dec 17, 2015
2answers
Motorola t5720: Why does my radio show 0.5 watt icon even when i am using the 1 watt channel?
It is possible the manual is wrong where it explains channels 1-7 (GMRS/FRS). When checking on line sources your example frequency on Ch 7 of 462.7125 is limited to .5 watt. http://wiki.radioreference.com/index.php/FRS/GMRS_combined_channel_chart With this in mind the icon on your radio is correct, and the manual is wrong on page 19. http://shop.giantintl.com/Manuals.asp? Best regards.
5/26/2015 2:28:08 AM • Motorola... • Answered on May 26, 2015
T5725 manual
Download it from here: http://www.motorola.com/mdirect/manuals/T56XX_57XX_User%20_Manual_E.pdf
2/24/2015 10:48:10 PM • Motorola... • Answered on Feb 24, 2015
Doesn't transmit
Check your battery. Transmitting takes more energy than receiving. Also, check your frequency and code settings. The radio you are using this one with might have a different code setting than yours. http://shop.giantintl.com/Manuals.asp
1/8/2015 6:13:30 PM • Motorola... • Answered on Jan 08, 2015
Lock the settings on motorola two way radio
Here's a link to the user guide http://shop.giantintl.com/Manuals.asp You can lock the keypad.
1/8/2015 6:12:13 PM • Motorola... • Answered on Jan 08, 2015
How to change batteries in motorola MG 160A wallow talkies
Here is a link to the user guide page http://shop.giantintl.com/Manuals.asp Select your model from the pulldown.
1/8/2015 4:36:27 PM • Motorola... • Answered on Jan 08, 2015
What are the power channels
TalkAbout T5720 is a 1/2 watt radio.
1/8/2015 4:35:49 PM • Motorola... • Answered on Jan 08, 2015
Maunal for T5700
http://shop.giantintl.com/Manuals.asp, use the pulldown to find your model
1/6/2015 6:51:17 PM • Motorola... • Answered on Jan 06, 2015
T5725 motorola manual needed
Here's a link to the user guide page, choose your model from the pulldown: http://shop.giantintl.com/Manuals.asp
1/6/2015 6:31:10 PM • Motorola... • Answered on Jan 06, 2015
2answers
Operating instrructions for a motorola talkabout 200
Contact Motorola Solutions Get Support Mark Motorola Mobility Support
1/6/2015 4:38:11 PM • Motorola... • Answered on Jan 06, 2015
Operating instructions for a motorola talkabout 200
1/5/2015 12:51:30 AM • Motorola... • Answered on Jan 05, 2015
What is scan mode
Scan mode is when you set your radio to scroll through all available channels looking for activity.
12/24/2014 3:50:34 PM • Motorola... • Answered on Dec 24, 2014
2answers
How to sync 22 channel motorola 2 way radio
both radios must be set to the same channel number. There is also a private code number that should be set to the same number on each radio.
8/28/2014 12:15:21 PM • Motorola... • Answered on Aug 28, 2014
Motorola Talkabout T5720 (7 Channels) 2-Way Radio Logo
174 questions posted
Top Motorola Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Radio Communications
Most Popular Question
  • Radio Communications
