20 Most Recent
Cfm Daikin R410a Split System Air Conditioner Questions & Answers
Lost manual for model R410A
google daikin (model number) manual . what are you trying to do or just want a manual ?they really dont tell you much in them.
How to fix Daikin aircon
This is a fault with the fan coils fan motor.
This could possibly be due to either an issue with the main PCB or the fan motor itself.
How to troubleshooting?
First of all, I am not a A/C repairman, but I do repair many other electronic devices. The first thing any repair person will need is a good service manual for the device, and I have found a link to one for you. I went over the site in quite a bit of detail, its a genuine Daikin site and rich with information.
Here is the link, and best wishes!
http://www.aircon-info.com/daikin-ac-service-manuals
U4 System transmission between indoor and outdoor units Daikin
Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
Hope this helps
I take the time to answer your question so please rate me
What is and how is
12000 BTU is 1 ton
300 - 350 CFM in 1 ton depends on mfg.
Cfm and Tonnage of Refrigerent is are different units, then how these two units can be compared
Cfm means air flow per cubic meter per hour.
Why does the split unit blow hot air in air conditioner mode, when switched on with the remote control.
because you have the temperature set at 28 degrees celcuis . Change the temperature to 18 degrees and it will cool 28 is hotter
It is a reverse cycle air conditioner it will warm the room if you set temperature to 28 degrees . Set it lower and it will blow out cold air.
Have exact same air conditioner as I recognise the remote control.
point it at the air conditioner when altering the temperature setting.
Check under the slide compartment also on the remote for more advanced settings.
How too solve daikin error code c4
c4 error code has nothing to do with outdoor pcb. Use code 41 to check the value of the liquid line sensor and test with mulit meter. Pretty rare fault. Turn the power off for 5
Mins and reboot your system.
